Re: The weekend lowering project
[Re: 76dodgeboy]
#795164
09/12/10 10:01 PM
09/12/10 10:01 PM
Posts: 1,093 It's beer:30 somewhere
adventurer
I took today and cut ![](/ubbthreads/images/graemlins/sawzall-smiley.gif) 1 1/4" off the rubber piece and reinstalled. Worked fine no more large clunk when hitting bumps. Just curious though has anyone ever cut out that metal piece that the bump stop bolts to so the suspension could travel farther?
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
[Re: adventurer]
#795166
09/13/10 01:00 AM
09/13/10 01:00 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
I took today and cut 1 1/4" off the rubber piece and reinstalled. Worked fine no more large clunk when hitting bumps. Just curious though has anyone ever cut out that metal piece that the bump stop bolts to so the suspension could travel farther?
Thats what they are refering to when they say they cut it out meaning they cut the whole bumpstop bracket out. Some have shortened the bracket aswell
[Re: Kevin I]
#795169
09/13/10 11:44 PM
09/13/10 11:44 PM
adventurer
I joined this site just now because I was linked to this write-up. I'll be doing the same thing to my 1980 big block D150 if I can find the lower control arms. Excellent write up.
I have one question. Did you use the existing coils up front?
Hello and welcome Kevin. Thanks for joining our group here. Yes you use the existing springs from your truck. Since you don't already have the lower control arms, I looked at the Pull-a-Part junkyard website for your area, they show at least 11 likely canidate vans for donors. If you have any more questions don't hesitate to ask. It really is a pretty simple deal to do this. Kevin are you going to the Music City Mopar Show on the 25th and 26th, since it's right in your neck of the woods? We'll be there with both my trucks for the weekend.
[Re: adventurer]
#795170
09/13/10 11:48 PM
09/13/10 11:48 PM
Posts: 718 Nunnelly, TN
Kevin I
Nunnelly, TN
I was there a couple weeks ago. It is just up the hill from where I work. I'll have to take my tools to work with me one day.
Great! I am planning to go. I look forward to meeting you and seeing your trucks. I don't know if I will bring any of my junk. I just finished lowering my 1998 SS/T and it still needs an alignment and the 1980 big block truck needs a few things done to it. I'll probably be in my wife's boring ole Durango.
[Re: Kevin I]
#795173
09/14/10 09:32 PM
09/14/10 09:32 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Welcome to the Madness Kev ![](/ubbthreads/images/graemlins/wave.gif)
Rickster
[Re: rickstershemi]
#795175
09/14/10 09:44 PM
09/14/10 09:44 PM
Posts: 2,833 Ontario Canada
Webster
Ontario Canada
As I said before mine were cut off years ago
Hmmmmm....must be married ![](/ubbthreads/images/graemlins/whistling.gif)
Rickster
You're Right 33 years ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Jere]
#795180
09/19/10 06:37 PM
09/19/10 06:37 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Great write up. I just have a few questions. I am lowering a '93 dodge dually. I already have the lower control arms that you all are using. For shorter springs I went with '94 3" lowering springs to get 2" of lowered ride height. in the back I replaced the stock shackles and replaced the front hangers with raised hangers. The stance is great but I ran into the issue of the tierods hitting the center link. and the steering input shaft hitting the upper control arm. How have you all worked these issues out. Is there a post on here that address it. Thanks for all the help
You dropped it more the 2". Stock 3/4 and half ton springs are what you want for 2" Go to rockauto.com and search the springs. They give load hieghts. These guys keep thier stock springs with these lower control arms. 1tons have a taller coil than half and 3/4.. I plan to do the opposite with my 3/4 ton and lift it with 94 4wd coils. Stock my coils are at 11.." tall and 94 4wds are 15"
[Re: Jere]
#795183
09/20/10 07:12 PM
09/20/10 07:12 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
It doesnt ride lower. Half and 3/4 tons use a coil that is 11" tall when on the ground and yours are 13.13" when on the ground installed on the truck so its actually only .13" taller do to the pocket. Free hieght for the stock 94 coils are 12.92dr and 12.63ps and thats not loaded. so take 3" out of than and its 9" for both plus 2"for the coil totaling 5" of drop. Did you put the springs side by side?
