Re: The weekend lowering project
[Re: adventurer]
#795146
09/08/10 02:27 AM
09/08/10 02:27 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Looks good! I'd love to find a nice clean truck like that to do something similar. I'd ditch the rear bumper and get one of those fiberglas rear pans. I'd also change to a 89/90 grille and a 70s front bumper.
I've been kind of thinking the same thing on the bumpers and grill. Just not completely decided what to do there yet. Thanks
Just remember the 81-85 86-90 and 91-93 have diff headlight locations. 81-85 and 86-90 are very close and grill setup can be swapped but you can see the headlight diff. Easy way is swap core support or if you can weld that way works too but 91-93 the core support and lower valance are needed aswell Looks good. My tires on my 73 Clubcab sat where yours do in the wheelwells in front but I had 205/75s. I have some pocketed control arms I plan to use with drop coils on my D code 74
[Re: adventurer]
#795151
09/08/10 09:52 AM
09/08/10 09:52 AM
Posts: 738 TN
'84 D150 Shorty
Pickup Man
Pickup Man
TN
A friend is doing an 84 Stepside. He was wanting to lower his too, but didn't know what to do on the front.
What year LCA's are you using? Are they out of your typical dodge van?
Thanks Chris
Mine came from a 82 3/4 ton van. The junkyard I went to had several of these vans one as new as 90 and the arms all looked the same. Maybe someone else with a little more knowledge can chime in and say what exact year models work. My understanding is any 3/4 or 1 ton van in those year models.
LCAs from B250s as well as newer B2500 are will work until at least '97 (mine are from a '97 B2500)
[Re: adventurer]
#795152
09/08/10 10:17 AM
09/08/10 10:17 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Clean looking truck Larry....Lucky Daughter
One thing more to do is: remove the factory Alignment Cam Adjuster Stop Plates so you can get more adjustment....ours needed the xtra range to get back to the factory alignment specs
Rickster
Rickster thanks for the advice. I really don't know what plates you are talking about could you please explain more and maybe a picture. The only plates I see are the one that the cam pushes against to adjust. Is that the one you are refering to? Thanks Larry
Yes those are the plates I'm referring too....had to remove them on our truck to get additional range to be in spec
Rickster
[Re: adventurer]
#795154
09/08/10 01:55 PM
09/08/10 01:55 PM
Posts: 2,833 Ontario Canada
Webster
Ontario Canada
Hey Larry I used stock shocks when I did mine I think I'm going to change them to something a little stronger....What did you use? The same on the back. The Truck is good on semi smooth road but a bear on those bad roads.
Hey Terry, I only changed the front shocks because I had the old ones out and they looked like the originals. I just used a stock replacement shock for it. The rears had been changed at some point and time. I'll have to drive it more to see how the ride is after I get it aligned on Thursday. so far I really don't see that much diffence in ride quality. On the front shocks changing the arms really didn't shorten the shock travel because the mounting point for the shock is lowered as well. So I wouldn't think changing the shock to a differnt shock on the front would help. Maybe cutting down the rubber bump stop. Now on the rear thats a diffenrt story. By lowering the truck it has shortened that shocks travel and it could be bottoming out. I am just going to drive it and see. If it feels harsh as far as bumps that it may be bottoming the shock out, I'll find a shorter shock for the rear. Maybe my roads are just smoother than your's Terry
I'm sure your roads are better than ours I cut the bump stops off of mine when I first lowered mine, no issue so far (over 5 Years) you might be right about the back shocks bottoming out ,I'll check too
[Re: Webster]
#795155
09/09/10 12:01 AM
09/09/10 12:01 AM
Posts: 158 Michigan
Mopar366
what kind of chevy are the 2" drop shackles off of? and what year van for the lca's
1982 d150
1993 dakota
[Re: Mopar366]
#795157
09/09/10 01:46 AM
09/09/10 01:46 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
You can go to autozone and get the drop shakles for $30
[Re: rickstershemi]
#795160
09/12/10 01:20 AM
09/12/10 01:20 AM
Posts: 1,093 It's beer:30 somewhere
adventurer
Latest update. Got the alignment done. While doing the alignment noticed the lower bump stop rubber bumpers were setting against the lower control arm at ride height. Unbolted them while doing the alignment. Which I beleive is going to be a mistake. Got the new wheels on today and really drove it quite a bit. When you hit a large bump in the road the lower control arm is coming in contact with the metal where the rubber bump stop bolted on and you get a loud clunk noise. So I am going to look into what I need to do for that. Any body else have an idea there? Now on to the pics of it as it is right now. just for comparison here is where I started Quite a bit of differnce there, if I do say so myself. I think it looks a lot better.
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
[Re: Webster]
#795162
09/12/10 10:09 AM
09/12/10 10:09 AM
rickstershemi
When I did mine, I drove it to the end of the street and saw the same thing. Cut them off and had no trouble after that. If I hit that big of a bump she all over with anyway Your Truck is lookin really Good
did the same thing....have had no problems although we didn't remove them I just trimmed them up 1" and never hits, but there if an extreme pot-hole may be encountered
Rickster
