Re: problems with 604" predator motor
[Re: B1Fish540]
#794830
09/08/10 12:29 AM
09/08/10 12:29 AM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
i am really surprised that MM didn't find the problem!!!! was he aware of the oil pressure prob.?
yes, that was the reason we took it to them.
Thats unacceptable..whats wrong with Mike, anyway..shheesh...
When i ask that i should have also asked: "Is there anything your not telling us?" Sorry Mike, but thanks for your side of the story.
[Re: go green]
#794831
09/08/10 12:37 AM
09/08/10 12:37 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Its not the oil viscosity . Oil weight, or viscosity, refers to how thick or thin the oil is. The temperature requirements set for oil by the Society of Automotive Engineers (SAE) is 0 degrees F (low) and 210 degrees F (high). The oil will be stable to the high limit operating zone .Are you suggesting the oil is far exceeding 300 to 400 F ?
That's basically what I was thinking. I can't see the water passages having anything to do with low oil pressure. Especially at start up... It should be up at 80-90+ lbs. There would be no heat in the engine to worry about..
The whole thing makes no sense..
Chris..
[Re: Eric]
#794833
09/08/10 01:07 AM
09/08/10 01:07 AM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
are you pushrod oiling? what lifters? is the block bushed? if so how big are the holes in the bushings? had a similiar prob. that I corrected,my mill was oiling way to much up top.I corrected It with a set of bushings with a.020 hole in the lifter.
[Re: boatracer572]
#794834
09/08/10 07:46 PM
09/08/10 07:46 PM
Posts: 73 Hartford,MI
goody340g
Hartford,MI
we are using spray bars, i'm not sure what lifters, blocked is bushed and there are no holes in the bushings.
nice looking motor by the way
[Re: goody340g]
#794835
09/08/10 09:22 PM
09/08/10 09:22 PM
boatracer572
San Jose Ca.
are you useing restrictors in the spray bars?
[Re: boatracer572]
#794836
09/08/10 09:34 PM
09/08/10 09:34 PM
goody340g
Hartford,MI
don't think so but i'll check tomorrow.
[Re: boatracer572]
#794839
09/09/10 04:03 PM
09/09/10 04:03 PM
goody340g
Hartford,MI
there are 2 bars in each valve cover and only 1 bar(in each valve cover) has a restrictor.
[Re: joshking440]
#794844
09/24/11 10:20 AM
09/24/11 10:20 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Goodson....what the hell are you doin taken that motor to Rutgers..... Hows Ernie and your Dad doing...been a while since I have seen you guys, are you going to Norwalk for the Classic? I see Jacobs is running the points...hit me up
Exactly...as far as i know rutgers does mainly chevy stuff, doesnt have any sort of machine shop of their own, they just send stuff out to be machined and screw stuff together.
I would never take an engine of that magnitude to somebody like that
