Re: problems with 604" predator motor
[Re: MuscleMike]
#794810
09/07/10 01:39 PM
09/07/10 01:39 PM
Posts: 2,119 sc
tjmarcus1
sc
As I recall your original engine builder overfilled the block with hard block. The engine has oil pressure on start up but since it does not circulate water with a traditional water pump (block overfilled) the oil gets hot after idleing for 10-15 minutes and looses it viscosity. I believe I suguested you could circulate water thru the heads and run the engine for short periods of time. Or get a new block (that is not overfilled)
Mike @ MM
see! i knew muscle motors was too good not to find a problem ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RT540]
#794812
09/07/10 04:23 PM
09/07/10 04:23 PM
Posts: 6,295 U.S.
moparniac
U.S.
I thought there was muratic acid or whatever could eat that stuff out ...
Mopar Performance
[Re: MuscleMike]
#794814
09/07/10 04:36 PM
09/07/10 04:36 PM
Posts: 778 Sherwood park, Alberta.
go green
Mike @ MM
I cant see this being the problem but putting a temp gauge would settle the argument.
[Re: MuscleMike]
#794815
09/07/10 05:07 PM
09/07/10 05:07 PM
Posts: 73 Hartford,MI
goody340g
Hartford,MI
Mike @ MM
mike talked to dad today and he did say that is what u guys came up with. i don't remember hearing anything about that at the time but i was just half a** helping them anyways. i apoligize if it sounded like i was knocking mm, that was not my intention, i know it is a pain to try a figure out somebody elses mess. i was just trying to pick some brains
[Re: go green]
#794817
09/07/10 06:20 PM
09/07/10 06:20 PM
goody340g
Hartford,MI
You cant diagnose the problem over the Internet with out a detailed parts list. What lifter and how much lump on the camshaft.To much lift you might be windowing the lifter skirt to the oil (you should be safe to .470 with most lifters)
When you dropped the engine off did you give them permission to completely disassemble and rebuild the engine ? Try a different pump ? Cranking the pump by hand you should see 40 to 50 psi if not the oil should be hosing out from somewhere. you should only see about a 10 psi drop from cold to hot.
i'll have to look up the specs on the cam, we tried many diff. pumps and gauges. so hopefully next week i'll have time to get it on a stand and prime it to see what the press. is cold
[Re: goody340g]
#794818
09/07/10 06:21 PM
09/07/10 06:21 PM
Quicktree
really what does it matter? you already know what the problem is ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: Quicktree]
#794820
09/07/10 08:20 PM
09/07/10 08:20 PM
goody340g
Hartford,MI
if you r giving new blocks away it doesn't matter, until then we'll exhaust all options ![](/ubbthreads/images/graemlins/smile.gif)
[Re: goody340g]
#794821
09/07/10 08:41 PM
09/07/10 08:41 PM
Quicktree
I r not giving any blocks away but somebody paid good money to figure out the problem, guess you are smarter than the guys at MM ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: go green]
#794825
09/07/10 09:52 PM
09/07/10 09:52 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
A lot more info needs to be provide to conclude or asertain the possible causes.How is the oil pressure on cold startup,how long before the oil pressure drops,what is engine temperture,oil temperture,and what is the cause of the heat? As mentioned is the filled block the issue?What do the bearings look like?A lot of guess work can be avoided by check the above mentioned issues.Oil passage cracks,plugged or restrictions as well as cooling issues can cause similar issues.We have seen one bad main cap,a crack in the block main bore at the oil passage as well the issues at the lifter bores cause the loss of oil pressure.An easy analysis of the fluid tempertures(which get hot first)would be a good start.Check and recheck all oil pickups,pumps,filters.lines and passages.Check and recheck all cooling systems and passages also.We find many issues are caused by simple over looked things. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: go green]
#794826
09/07/10 09:57 PM
09/07/10 09:57 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
If it was my engine, I would add a few things and run it...What are you going to do junk the block? I would add a oil cooler, probably get the whole thing cheap if you look around. Next I would add alky injection, via Rons Terminator. Its the ultimate in hp over any carb setup. First hand experience says you will pickup substantial e/t with this I assume you already have a sheet metal intake so this would be easy. Make the best with what ya got. ![](/ubbthreads/images/graemlins/Twocents.gif) The alky will take care of any cooling issues you have. Then the oil cooler will take care of oil temp issue's. ![](/ubbthreads/images/graemlins/Twocents.gif)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
