Re: How did OEM wheel lip moldings fit? E body.
[Re: PAINT IT BLACK]
#794760
09/07/10 09:28 AM
09/07/10 09:28 AM
Posts: 4,799 ILL
MLR426
ILL
Nos or original wheel lip mouldings never fit perfect, I had to use a crimping tool to get a better fit and then sand and buff to finish, not to a bright finish just a satin finish.
logan426
[Re: MLR426]
#794761
09/07/10 10:20 AM
09/07/10 10:20 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
logan426
But they are anodized... right? Did you buff the anodizing off?
#794762
09/07/10 11:51 AM
09/07/10 11:51 AM
Posts: 4,799 ILL
MLR426
ILL
logan426
yes on the large flat area.
logan426
#794764
09/08/10 07:13 AM
09/08/10 07:13 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I had to massage mine a bit too. Mostly the rears. They fit pretty well after about an hour of work to get the shape closer to the bodylines on the lower portions
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#794765
09/08/10 10:00 AM
09/08/10 10:00 AM
PAINT IT BLACK
Houston Texas
What do you mean by "massage"?
I sure wish someone had some pics of OE moldings installed.
[Re: Convertcuda]
#794766
09/08/10 10:02 AM
09/08/10 10:02 AM
PAINT IT BLACK
Houston Texas
Hi Logan, Can you show a pic of this cool tool?
Ken
Yes, please.
[Re: ScottSmith_Harms]
#794768
09/08/10 10:42 AM
09/08/10 10:42 AM
Posts: 2,304 WI
RestoRick
WI
The best time to fit these monsters is before the car is painted. Forget the factory holes.. weld 'em shut and start over, unless you're working with originals and you've been blessed with one of the cars like Scott mentions with perfect fitting mouldings. ![](/ubbthreads/images/graemlins/smile.gif) Clamp them in place with "spring loaded hand clamps" & orient them for the best fit. Drill & screw down one hole at a time using the same size pan head screw as your finish ones will be... no sense trashing your final attaching hardware. Sometimes a slight reshaping of a fender line, etc. can be done for a minor misfit too. This method also gives you time to send out your mouldings to be stripped & reanodized if you end up trashing the coating from manipulating them to fit. (Assuming they're anodized ones). Cutting & rewelding them usually won't work... the different alloy of the filler rod will typically "take" the anodizing different and be visible. And last... yes some fit better than others, but I haven't worked with enough different ones out there lately to comment on who's fit better than whose or who is selling who's parts. <-- sounds like a sentence from a Dr. Suess book... lol Rick
[Re: RestoRick]
#794770
09/08/10 04:48 PM
09/08/10 04:48 PM
PAINT IT BLACK
Houston Texas
I don't know if I care at this point. It's either do that or have lip moldings on my Cuda that look like they were made for a 2006 Toyota 4 Runner. I'm only exaggerating a little bit.
#794771
09/08/10 07:05 PM
09/08/10 07:05 PM
Posts: 18,160 Mass
DAYCLONA
Mass
What you need to put an end to your misery is a hand stretcher/shrinker,....I use one to straighten Charger mouldings for my customers conversions to Daytonas,...if it can move and straighten a 45 degree bend in a stainless moulding, it can certainly move an aluminum Cuda moulding,....if your delicate with the shrinking/expanding action, it'll leave small teeth marks, very much like whats already on your moulding,....buy a quality unit, as it'll have more than enough service in your shop to warrant the expense,...Eastwood has a nice USA made unit for about $300,...the cheaper offshore unit isn't worth the time, looks the same 1/2 the price, completely worthless
Mike
