Re: New E85 carb installed [Re: 412 SB Duster] #794437
09/07/10 11:46 PM
09/07/10 11:46 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Al...........I'd have to say those are in there for initial predictions.
After you log enough clean passes under different weather conditions,
it will start predicting ET based on the trend your car establishes.
Re: New E85 carb installed [Re: S/ST 3040] #794438
09/07/10 11:55 PM
09/07/10 11:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what my TAG unit does... it couldnt care less
what the fuel is ... it just sees the ET difference
(that I put in after a run) vs the weather at that
time
Re: New E85 carb installed [Re: S/ST 3040] #794439
09/07/10 11:57 PM
09/07/10 11:57 PM
412 SB Duster Offline OP
Just going to take some time to track it. I keep good records so i'll get it. just trying to get a head start. LOL
I'll update how it goes after I run it.
Re: New E85 carb installed *DELETED* [Re: 412 SB Duster] #794440
09/08/10 12:09 PM
09/08/10 12:09 PM
OH
junkyardmaxie Offline
OH
Post deleted by junkyardmaxie
Re: New E85 carb installed [Re: junkyardmaxie] #794441
09/08/10 09:28 PM
09/08/10 09:28 PM
NC
440Jim Offline
440Jim  Offline
NC
WITH A BIG BLOCK 440 WHAT KIND OF TIMING DO YOU RUN WITH THE E85 SET UP? THANKS
Start a new topic with a good descriptive title and your combo. I think you will get more and better information that way.
