Re: This totally stink's,,lot's of work ahead of me.
[Re: dartman366]
#793492
09/05/10 09:47 PM
09/05/10 09:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've seen that one other time Bill... it actually cracked all the way around... the trans worked but had a BAD clunking sound and a bad vibration... the only way I noticed it was I put the jack under the pan to lift it to see if the trans mount was bottoming out but the front lifted instead of the rear... I still dont know what caused it ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#793496
09/05/10 11:04 PM
09/05/10 11:04 PM
Posts: 5,763 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Now THAT'S scarey!!
I think the converter was the only thing that was holding up the front
I have done it before lmao, mine had an inch before it was all the way broke. I did what your doing, transfering guts to another case. Get a 200buck clutch kit and be done for another few years. Or atleast check em with a feeler guage to see where it's at.
[Re: FastmOp]
#793497
09/06/10 08:49 AM
09/06/10 08:49 AM
dartman366
Mt. Vernon, Ohio
Now THAT'S scarey!!
I just freshened this one up this spring and it was working great, but I will go thru the clutches and stuff just to make sure.
DoubleD, I run a motor plate and limiters but with a stock rubber tranny mount, I know about the Turbo 400's having this issue and so do the stock powerglide's. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: colt340]
#793499
09/06/10 05:10 PM
09/06/10 05:10 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Bill, if you can't get it done, I have a fresh CRT trans sitting on the shelf. Never installed, waiting for a project that will never happen. You can use it if in a pinch. it was built for an 850 HP heavy car, so it's a great piece.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#793500
09/06/10 08:05 PM
09/06/10 08:05 PM
dartman366
Mt. Vernon, Ohio
bet it ain't a 904 tho, thanks for the offer Rich,,,the new one is a work in progress as I got the case prepped today and will be assembling tomorrow if all go's well with the gut's from the broken one. ![](/ubbthreads/images/graemlins/luck.gif)
[Re: dartman366]
#793502
09/07/10 09:41 AM
09/07/10 09:41 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I've seen 2 904's do this - 1 had been extensively cleaned up to remove all the casting seams, etc. and had a lot of material removed in that area; the other was a stock case. Both of them cracked after other driveline parts failed and the driveline unloaded under full power.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#793503
09/07/10 01:39 PM
09/07/10 01:39 PM
dartman366
Mt. Vernon, Ohio
well the tranny's back together and I am waiting to pick up the converter in the morning, I did have a front U joint that was loose and I replaced it and the driveshaft had been balanced and no weights are missing, It all go's back in thursday and hopefully I can test it out saturday at Pacemaker's. ![](/ubbthreads/images/graemlins/luck.gif)
[Re: S/ST 3040]
#793505
09/07/10 03:07 PM
09/07/10 03:07 PM
dartman366
Mt. Vernon, Ohio
Sorry to hear this Bill. At least you caught it before Norwalk. I hope I see you there.
Thanks Vic, don't worry I will be there, fresh tranny, fresh converter and all tuned up, and ready for 10.00000's again. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: MR_P_BODY]
#793507
09/09/10 03:00 PM
09/09/10 03:00 PM
dartman366
Mt. Vernon, Ohio
Glad to hear you got it all back together... lacking the install
Well Mike the install is complete, Walt and I put it in this morning and fired her up and all seem's to be good, I hope so cause I may not get to test this weekend and the last chance is Norwalk. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: dartman366]
#793508
09/09/10 03:17 PM
09/09/10 03:17 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
next pic. has this happened to anyone else?
I had the tail shaft housing break completely in half...does that count?
