Re: Show me your big block valve covers
[Re: Mr.Yuck]
#792904
09/08/10 05:03 PM
09/08/10 05:03 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
old school Moroso's. They are taller, I'm running 1.5 rollers and zippy issues.
I like those, too...but wish they offered a "no-logo" version. Right now, nobody offers the tall stock looking covers w/out a logo..at least I have not found any.
[Re: BloFish]
#792907
09/08/10 06:27 PM
09/08/10 06:27 PM
Posts: 8,881 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Quote: -------------------------------------------------------------------------------- Quote: -------------------------------------------------------------------------------- I will find a smaller distributor -------------------------------------------------------------------------------- Good luck with that !!!! -------------------------------------------------------------------------------- https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD I'm pretty sure the Firecore unit is the same size as the MSD pro billet.
[Re: BloFish]
#792919
09/10/10 02:09 PM
09/10/10 02:09 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Just as everyone told me, I need aftermarket valve covers with the flange on the inside due to the Harland Sharp rockers I just installed on my stage VI heads. ...
I won't show you a picture, but I've been running HS rockers on my S6 heads with factory covers forever. At first I ovalled the holes and shoved the covers a little toward the intake and used a little (very little) hammer work on the covers. Last time I had it apart I took a close look at things and found it's only the end exh. rockers that interfere and these rockers have extra (unneeded) material in that spot. A little grinding on the 4 end rockers and everything clears fine with factory covers. If you compare the intake and exhaust rockers, they use the same body, the only difference is where the adjuster is placed. The result of this is excess mass just to keep costs a little lower. I think it's time HS makes dedicated right and left rockers, it would reduce the mass and polar inertia while correcting the clearance problem. Now to read what others have said...
[Re: @#$%&*!]
#792920
09/11/10 10:32 AM
09/11/10 10:32 AM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Attention, everyone who has spent the big money for aluminum heads. DO NOT GRIND THEM just to fit the MSD distributor. Our mechanical distributor fits with plenty of clearance. It also will keep timing exact throughout your rpm range, which leads to zero retard, which leads to more topend. . Jim Guy is trying one out, and was blown away, so far, by the performance and fit of it. He is at MM in St Louis right now, testing it further. So far, he loves it..
