Hellwig tubular anti-sway bar #791750
09/03/10 04:46 PM
09/03/10 04:46 PM
AndyF Offline OP
AndyF  Offline OP
Just got one the other day. This one is for a 73+ A-body. It is 1.125 diameter but only weighs 8 lbs. The 1.125 solid B-body bar that I have on hand weighs 18 lbs. It is a bit longer but still, there is a big difference. We're planning to put this bar on the '68 Valiant. That should be another 6 lbs off the nose of the car. Price on the bar is really fair considering how nice these are. All of the brackets and hardware are included.
Re: Hellwig tubular anti-sway bar [Re: AndyF] #791751
09/03/10 05:29 PM
09/03/10 05:29 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Thanks for the info Andy. I have a 1.125 Addco solid bar on the Cuda now and yes it is heavy. One of my friends had a solid Hellwig bar on his car and it appears to me to be a better fit ie. curved more like the factory bars.
Re: Hellwig tubular anti-sway bar [Re: 5spdcuda] #791752
09/03/10 07:20 PM
09/03/10 07:20 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I put a Hellwig rear bar on my 69 B'cuda last spring. Great fit,great customer service!!! I'll be putting their big bar on the front next spring
Re: Hellwig tubular anti-sway bar [Re: AndyF] #791753
09/04/10 02:08 AM
09/04/10 02:08 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I used to be a Camaro guy until I bought my Charger in March 2000. Tubular sway bars were first becoming popular then.(Maybe even before?) I have yet to understand how a hollow tube can be as effective as anything solid. I am not saying that it isnt possible, but I would like it if anyone could offer an easy to grasp explanation.
Re: Hellwig tubular anti-sway bar [Re: Kern Dog] #791754
09/04/10 02:16 AM
09/04/10 02:16 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
All of the resistance to twist is in the outer surface area of the bar... The metal in the center offers little resistance & extra weight..
Re: Hellwig tubular anti-sway bar [Re: 1_WILD_RT] #791755
09/04/10 03:01 AM
09/04/10 03:01 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
To be more precise, if the interior space on the bar is say 7/8", one could deduct the rating of a 7/8" solid bar from rating of a larger diameter solid bar to reach the new rating of a tubular bar. It is not as maybe implied above that all the resistance to twist is on the outer surface, it is that the outer surface on any object is more resistant/effective to resist twist then the interior.
Re: Hellwig tubular anti-sway bar [Re: jcc] #791756
09/04/10 03:14 AM
09/04/10 03:14 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Wow. That last response was not all that easy to follow. Thanks anyway.
Re: Hellwig tubular anti-sway bar [Re: AndyF] #791757
09/04/10 03:38 AM
09/04/10 03:38 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Tell me how well we got it to fit. Took four trys, but I was happy with the end fit.
My measurements on a just a shipping scale
Factory 7/8" Solid Sway Bar 7 lbs
Addco 1 1/8" Solid Sway Bar 13 1/2 lbs
Hellwig Hollow 1 1/8" Sway Bar 7 3/4 lbs
Hellwig Hollow 1 1/4" Sway Bar 8 3/4 lbs
You'll notice the center is not exactly curved like original. That is because it is a thicker bar and it will hit the K-member if you just make the factory bar "thicker". And it wouldn't be a bad idea for someone to give it some extra room just in case if someone wanted an even bigger diameter bar.
Re: Hellwig tubular anti-sway bar [Re: Kern Dog] #791758
09/04/10 04:47 AM
09/04/10 04:47 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
You got me interested in some college history.
The formula for torque for a rod of circular cross-section is 1/2*pi*stress*R(cubed). Where stress is the strength of the material the rod is made of. I used 80,000 psi for the calcs, but it doesn't matter. R is the radius of the rod. For a hollow rod, it is simply 1/2*pi*stress*(R(cubed)-r(cubed)).
R is the outer radius, r is the inner radius.
A 7/8" diameter solid bar yields the same torque capability (876 foot-pounds, in this case) as a 1.25" bar with a .543 inner radius (1.086 inner diameter). Or stated another way, equal to a 1.25" hollow tube of wall thickness .082".
Interestingly, the hollow tube has a cross-section area of .3009 square inches. The solid bar has a cross-section area of .6013 square inches. Assuming the same length bars and ends (a bit of a stretch), the hollow bar would be almost 50% lighter.
Re: Hellwig tubular anti-sway bar [Re: MoparMarq] #791759
09/04/10 01:21 PM
09/04/10 01:21 PM
AndyF Offline OP
AndyF  Offline OP
Hollow torsion bars would be a nice product but they are tough to make.
Re: Hellwig tubular anti-sway bar [Re: AndyF] #791760
09/04/10 01:43 PM
09/04/10 01:43 PM
hawaii
P
pauly v.100 Offline
pauly v.100  Offline
P
hawaii
Re: Hellwig tubular anti-sway bar [Re: AndyF] #791761
09/04/10 05:55 PM
09/04/10 05:55 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I remember a place called Sparks out of New York said they would make hollow T-bars. That place also claimed to be selling Kit Car Plans. Anyone remember that place. Advertised in Mopar Action I think.
They make gun drilled axles, so T-bars are possible. Just how much money you want to spend.
I think there are hollow T-bars for Sprint Car on the market.
Re: Hellwig tubular anti-sway bar [Re: autoxcuda] #791762
09/04/10 11:11 PM
09/04/10 11:11 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I think I still have some hollow torsion bars made by Schroeder for a midget....been sitting in my basement for years. Had a midget that ran rear torsion bars and a coil-over front.
Re: Hellwig tubular anti-sway bar [Re: autoxcuda] #791763
10/11/10 01:40 AM
10/11/10 01:40 AM
AndyF Offline OP
AndyF  Offline OP
I finally got the car back up in the air and did the install. The engine is out waiting for a new oil pan so it was a good time to install the new Hellwig anti-sway bar. I made my own end link spacers from 1 inch aluminum bar stock. The large diameter spacers will stiffen up the bar a little bit.
Re: Hellwig tubular anti-sway bar [Re: AndyF] #791764
10/11/10 04:53 AM
10/11/10 04:53 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Andy how did you like the fit inside the K-member? I really tried and pushed to get it centered in there because I know a lot of K-members get crushed making it even tighter.
BTW are you getting one of those new Milodon SB Road Race baffled pans? I told Steve how your Charlies pan lost oil pressure just after you came back from PIR testing. I thought one was going up there.
Re: Hellwig tubular anti-sway bar [Re: autoxcuda] #791765
10/11/10 11:42 AM
10/11/10 11:42 AM
AndyF Offline OP
AndyF  Offline OP
We're supposed to be getting one of the Milodon pans but it hasn't arrived yet.
Re: Hellwig tubular anti-sway bar [Re: AndyF] #791766
10/11/10 03:02 PM
10/11/10 03:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Andy how was the installed clearance inside/thru the K-member on Tim's car?
Re: Hellwig tubular anti-sway bar [Re: autoxcuda] #791767
10/11/10 04:01 PM
10/11/10 04:01 PM
AndyF Offline OP
AndyF  Offline OP
Clearance was fine. I tweaked the mounts a little bit to get things right where I wanted it.
Re: Hellwig tubular anti-sway bar [Re: AndyF] #791768
11/04/10 02:04 AM
11/04/10 02:04 AM
AndyF Offline OP
AndyF  Offline OP
Here is another installed picture. Shows some of the other details.
Re: Hellwig tubular anti-sway bar [Re: AndyF] #791769
11/04/10 07:43 AM
11/04/10 07:43 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
Andy, IF you had to mount the bar 1.5" lower( on the bottom of the Kframe instead of through it)-using 1.5" square tubing instead of the flat 1/4" plate supplied--- do you see any drawback?
I do not think ground clarance would be an issue as my oil pan is the low point.
It does look like it would interfrere with the "Jacking" point on the bottom of the k frame.
