Re: limiting mechanical advance in MP dizzy?
[Re: Challenger 1]
#791701
09/03/10 04:57 PM
09/03/10 04:57 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Yep...usually just taking a good look at it and adjusting accordingly will get you where you need to go.
If that seems like an odd thing to do or it doesn't seem to make any sense, the kit is P5153446.
The kit is very nice, but it's like Pandora's box... it comes with 16 keys to measure the advance slots, and 15 different springs, and an instruction sheet that is the length of a short novel...so it's probably more than you actually need to get it in the ballpark of where you want it.
Pull the rotor off....if the metal under the rotor looks like brass, it's the Mallory mechanism. If it looks like steel, it's the Chrysler mechanism.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#791702
09/03/10 05:31 PM
09/03/10 05:31 PM
Challenger 1
Cincinnati, Ohio
One thing I should add is, on the 2 MP dist that I bought new at the same time. Both pickup assys gave me trouble, the car would run fine at idle but when I drove it under load it would breakup and miss fire. Lot's of back fire and ran like crap. Of course I tried adjusting the air gap with my .007 brass feeler gauge. That did not help, what fixed the problem completely was replacement of the magnetic pickups with used one's I had in other stock dists. I still have those used pickups in there as I wanted to get new ones for them someday but haven't. I ohmed the pickups in my new MP dists before replacing them and both ohmed differertly than the stock used one's I had. Sucked when I first installed the dists because of this problem. I swear this happened on both of my cars, 340-440 But now I like the dist because the advance is so easy to adjust/change along with the advance curve. This was my experince with both a sb and bb dist. the third one I setup for a friend, I don't think he had that problem. I bought both mine at the same time around 2006 FWIW Adjust the slots about halfway closed and stick it in there. Set the idle timing at what you want and check the over all timing and adjust from there. I always take the dist out of the car and stuck it in a vise so I could make accurate adjustments. Get after it!!
[Re: Challenger 1]
#791703
09/03/10 05:46 PM
09/03/10 05:46 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I still have those used pickup in there as I wanted to get new ones for them someday but haven't. I ohmed the pickups in my new MP dist before replacing them and both ohmed differertly than the stock used one's I had.
Ran into the same problem with the vacuum advance type distributors. Replaced the reluctor and pickup with one out of an old distributor.
I bought the billet one and it worked fine. Same advance mechanics as the vacuum unit
[Re: torkrules]
#791704
09/03/10 06:31 PM
09/03/10 06:31 PM
Challenger 1
Cincinnati, Ohio
Yup, both of mine are vacuum advance units.
[Re: ZIPPY]
#791707
09/04/10 10:40 AM
09/04/10 10:40 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
I bought the Mallory kit from summit, was pretty easy to adjust and the novel seemed like a short story , the hard part was getting the rollpin in the right place when putting the reluctor wheel back on.
[Re: 67_Satellite]
#791708
09/04/10 10:47 AM
09/04/10 10:47 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Hey Paul, I bought my curve kit from jegs a few years ago. The jegs part number is 312-p513446, and its labeled as a Mopar part. My kit is mallory and Im pretty sure they are one in the same. Not sure how convenient it would be for you to pick up, but you're welcome to use my kit if you want. I set up my mp distributor with 16 degrees advance 20 initial and 36 total, and that seems to work pretty good.
2 kids and a dog
[Re: PHJ426]
#791710
09/05/10 02:13 AM
09/05/10 02:13 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
FYI- I copies this from an old thread. It shows you how big to leave the slots for a given amount of advance. Quote:
dist. degrees X 2 + initial= total
dist. degrees / slot size 6.............. .340 7............... .355 8............... .375 9............... .390 10.............. .405 11.5 ........... .420 12.............. .435 13.............. .445 14.............. .460 15.............. .475 16.............. .490 17.............. .505 18.............. .520
[Re: hemigod426]
#791712
09/09/10 06:09 PM
09/09/10 06:09 PM
Posts: 9,894 Weddington, N.C.
Streetwize
Weddington, N.C.
FWIW....the old backyard hot rod trick we used to do was just wedge a small square of Mr Gasket white header gasket material into the outside of the slots to limit the pin travel, it sits in there tight and centrifugal force holds it in. Welding means you cant really turn it back to stock without having to ever grind it back out. in any event it's easy to try and see if it gets you where you want it without "fully committing". This way your centrifugal is limited and you run more initial, five minute drag strip tune that works every time. Remember the dizz only turns 1/2 the crank speed. My strokers like about 20-22 initial BTW.
[Re: PHJ426]
#791714
10/15/10 10:28 PM
10/15/10 10:28 PM
Challenger 1
Cincinnati, Ohio
Do you loosen the adjusting screws and make the opening windows for the mechanical advance slots smaller?
Yes
