235 tire on 5.5" rim? #78846
06/23/08 06:27 PM
06/23/08 06:27 PM
central PA
mopartial Offline OP
central PA
OOOPS! 1) Bought tires (235/60/14), 2) Measured rims (5.5"), 3) Found rims 1" too narrow than minimum recommended for tire.(6.5") Is this too far? (Mild SB A-body driver)
Re: 235 tire on 5.5" rim? [Re: mopartial] #78847
06/23/08 06:59 PM
06/23/08 06:59 PM
I ran 245-60-14's on 5.5in. rims for years on my Duster. They worked fine.
Re: 235 tire on 5.5" rim? #78848
06/23/08 07:15 PM
06/23/08 07:15 PM
central PA
central PA
Thats good to hear. Thanks.
Anyone else?
If it aint broke, dont break it.
Re: 235 tire on 5.5" rim? #78849
06/23/08 07:32 PM
06/23/08 07:32 PM
stratford,ontario,canada
JD340 Offline
JD340  Offline
Ditto on my Dart. No issues!
Nothing to see here. Carry on.
Re: 235 tire on 5.5" rim? [Re: mopartial] #78850
06/23/08 07:35 PM
06/23/08 07:35 PM
Norway
Dart270 Offline
super gas
Dart270  Offline
super gas
Norway
I had 225/60-14 on 6" rims, I did not like it.
Max recommeded tire on 5,5" rims is 215.
360/300 Crate Magnum, Ram Air filter box, 727TF, 8-1/4 suregrip,Rally susp., Koni shocks, 0.92 T-bar, 1.25 fr. & 7/8 rear sway bar. Moog offset bushings, 73 front disk, TTI headers&exhaust, AAR fiberglass Hood, Firm Feel K-member, Stage 2 PS.
Re: 235 tire on 5.5" rim? [Re: Dart270] #78851
06/23/08 08:00 PM
06/23/08 08:00 PM
central PA
central PA
What was it that you didnt like?
Re: 235 tire on 5.5" rim? #78852
06/23/08 08:37 PM
06/23/08 08:37 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
I know a few guys who have 245/60/14 on 5.5" wheels without any problems. One guy has been running this combo since '89
Re: 235 tire on 5.5" rim? [Re: mopartial] #78853
06/23/08 08:41 PM
06/23/08 08:41 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Not enough rim width for that tire.
Re: 235 tire on 5.5" rim? [Re: Michael] #78854
06/23/08 10:47 PM
06/23/08 10:47 PM
central PA
central PA
Michael, can you elaborate? What kind of problem would this mismatch lead to?
I read about 1) shortening of tire height (slight) and 2) change in profile of sidewall moves flex/stress point to where it doesnt belong and could lead to tire "failure", theoretically. But experience of several above suggests "no problemo".
What do you say?
Thanks for input.
Re: 235 tire on 5.5" rim? [Re: Michael] #78855
06/23/08 11:17 PM
06/23/08 11:17 PM
The places I priced tires at didn't want to go anything over a 215 on a 5.5" wheel.
Re: 235 tire on 5.5" rim? #78856
06/24/08 10:18 AM
06/24/08 10:18 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The trouble comes in when you inflate the tire. Too wide a tire changes the bead angle and reduces the contact area between the bead and rim allowing a greater chance of the tire losing it's seal under side loading.
Re: 235 tire on 5.5" rim? [Re: mopartial] #78857
06/24/08 11:26 AM
06/24/08 11:26 AM
Kirkland, Washington
Pacnorthcuda Offline
I wouldn't be doing any hard cornering with loved ones in the car.
Re: 235 tire on 5.5" rim? #78858
06/24/08 02:26 PM
06/24/08 02:26 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
me too. They are a really nice fit. Not tight at all.
I'm currently running 305 50 15 on a stock cop wheel. It was a pain to get on, but it works.
Re: 235 tire on 5.5" rim? [Re: stumpy] #78859
06/24/08 10:54 PM
06/24/08 10:54 PM
central PA
central PA
Now that makes sense.
Thank you Stumpy for useable info.
Re: 235 tire on 5.5" rim? [Re: Pacnorthcuda] #78860
06/24/08 10:55 PM
06/24/08 10:55 PM
i would...
Re: 235 tire on 5.5" rim? #78861
06/24/08 11:45 PM
06/24/08 11:45 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
A friend ran 245/60-14" on a 5.5" rim. The pressure needed to be around 20 to 25 psi to get an even tread pattern. Handling will suffer, but traction will increase. This was in a 440 Dart with /6 torsions and 90/10 shocks, so handling sucked anyways.
Re: 235 tire on 5.5" rim? [Re: stumpy] #78862
06/25/08 09:34 AM
06/25/08 09:34 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
BFG has a chart somewhere on their site. 235s are too wide for a 5.5" rim. They won't handle the eay they should because the sidewall is drawn to tightly inward. They won't seal as well because the bead is at an incorrect angle and the contact pattern on the street will never be as the manufacturer intended. The ideal is to have the tire towards the middle of the rim range, for better handeling use the widest reccomended rim. A 235 on a 7" rim will measure 1" more if mounted on a 8" rim.
Re: 235 tire on 5.5" rim? [Re: mopartial] #78863
06/25/08 09:45 AM
06/25/08 09:45 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Hey face it: It will go on but it ain't right and they more than likely will be short lived and have very poor wear and handling characteristics. The beads will be sucked in, the face will never full contact the road surface the way it is designed to(unless you run low air pressures [that alone is unsafe]). Running low tire pressure to get contact surface creates excessive heat. Hell in short it won't even look good all sucked in on the rim. Kind of like a fat lady with a too tight girdle. Oh and if I were running a tire shop I wouldn't mount them on those rims either.
Re: 235 tire on 5.5" rim? [Re: MoparforLife] #78864
06/25/08 09:53 AM
06/25/08 09:53 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Your car will handle like a drunk Water Buffaloe. That is reason enough not to do it. Think safety first.
Re: 235 tire on 5.5" rim? [Re: dmerc] #78865
06/25/08 11:48 AM
06/25/08 11:48 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
You gotta love the 'net, 180° disagreement (as usual).
I attended a seminar on rigging, hoists, chains, cables, etc some years ago. A question arose on whether someone could weld a hoisting hook onto an item instead of bolting it. After some discussion and naysaying from some 'experts' in the crowd, the final response of that factory rep was 'Do you think you know more about our products than we do?'.
I'm sure this comment will anger the folks driving on this tire setup, but I would trust the tire manufacturers recommendations more than the heresay of individuals that may or may not have the same car, same vehicle weight, driving habits, judgment, etc, as you.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
