Re: Truck 440 build advice
[Re: Suregrip]
#786225
08/28/10 07:50 PM
08/28/10 07:50 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
Wish I could help you with those questions. Like I said in the first post, I'm not an engine builder by any means. The stroker suggestion was as much a question as it was a suggestion. In terms of pistons, cam, and so on, I think it's all going to depend on each other. The pistons will depend on the stroke (I think ![](/ubbthreads/images/graemlins/shruggy.gif) ) and will depend on what compression you want. I don't know what compression would be ideal for towing, considering the 76 MH 440 I have has about a 7:1 or 7.5:1 compression and pulled that bigazz motorhome around easily. But would more compression produce more torque? ![](/ubbthreads/images/graemlins/shruggy.gif) Cam choice is going to depend entirely on compression. And converter choice is going to depend on the engine package as a whole. I know, that doesn't help at all, does it! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: dodgeram440]
#786226
08/28/10 09:04 PM
08/28/10 09:04 PM
Posts: 473 Fort Lauderdale, FL
Suregrip
Fort Lauderdale, FL
I was just wondering if I should be trying to keep the compression low like 8:1, or could I still go zero deck with some Ross pistons at 10:1 and have probably around 9.5:1 actual compression. Would that be too much for towing? Would I be pinging on Super Unleaded? Still wondering which cam and convertor. I would think a low to mid-range cam would build too much cranking compression for towing with 9.5 compression. The convertor I would think would be pretty tight for towing so the engine would be right into the low range torque? 440 Source has strokers for around two grand but I really don't want to spend that much if I don't need to...
Some people you just can't reach...
[Re: ahy]
#786228
08/28/10 10:08 PM
08/28/10 10:08 PM
Suregrip
Fort Lauderdale, FL
Thanks, that's exactly the kind of thing I was looking for. The 452's on my current 77 440 are in good shape and I would like to keep them for durability in towing. So I guess what would be the piston choice and cam for these heads with a close to stock stall converter? I know the cam would be a low/mid-range piece, but how about a piston recommendation? KB? Ross? Silvolite?
[Re: RapidRobert]
#786230
08/29/10 04:06 AM
08/29/10 04:06 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
SUM-K6400 Summit Cam and Lifter Kits Cam and Lifters, Hydraulic Flat Tappet Advertised Duration 272/ 282 Duration at 050 inch Lift: 214 int. /224 exh. Lift .442/ .465 with 1.5 rockers Basic Operating RPM Range: 2,000-4,500 Lobe Separation (degrees): 112 Camshaft Gear Attachment: 1-bolt Recommended Camshaft Style Flat tappet hydraulic Installed Height (in) 1.800 in. Seat Pressure at Installed Height (lbs) 121 lbs. Open Height (in) 1.300 in. Open Pressure (lbs) 298 lbs.
This info below is for the KB184 piston
ENTER YOUR DATA CALCULATED DATA Cylinder Head Volume (cc) 78 Piston Head Volume (cc) -2 Gasket Thickness (in.) .044 Gasket Bore (in.) 4.5 Cylinder Bore Diameter (in.) 4.35 Deck Clearance (in.) .08 Stroke (in.) 3.75 STATIC COMPRESSION RATIO 09.40 OPTIONAL DATA Rod Length (in.) 6.758 Adjusted Stroke (in.) 3.255 Intake Closing Point (degrees) ABDC @ 0.050 lift plus 15 degrees 49 DYNAMIC EFFECTIVE COMPRESSION RATIO 08.29
I didn't CC anything on my motor(I think....I repeat I think that this is close to the compression that I'm running) 76 block with 71 steel crank and 67 915 heads.
Moparlee
[Re: Robbins]
#786231
09/02/10 07:15 PM
09/02/10 07:15 PM
Suregrip
Fort Lauderdale, FL
Still looking for more 440 cam, piston/comp, torque convertor recommendations for towing...
[Re: Suregrip]
#786232
09/02/10 08:33 PM
09/02/10 08:33 PM
Robbins
Joplin, MO USA
I'm going to use mine for towing. The TQ I got...is from SMR which he spec'd out for the combo with towing in mind.
Moparlee
[Re: Robbins]
#786233
09/03/10 06:10 PM
09/03/10 06:10 PM
Suregrip
Fort Lauderdale, FL
I was looking on Jegs at their cams and might go with the cam like the one suggested only one size smaller with the power between 2000-4000rpm. Also for the last poster what stall was that convertor you had built and what gears are you running? Anyone else?
[Re: Suregrip]
#786234
09/03/10 10:01 PM
09/03/10 10:01 PM
Posts: 1,672 Virginia
HemiStan
Virginia
Here's my combo. I'm not saying that it is the best, but it is what I have. 1978 W200 4 speed manual with 4.10's 33" BFG's 1977 motor home 440 (.030 over) Stock valve job on factory motor home heads Speed Pro 9.0 to 1 cast pistons Rebuilt stock bottom end (cast crank) Lunati Voodoo 60303LK cam Voodoo Cam Edelbrock Performer RPM intake Holley 750 CFM vacuum secondary Heddman Headers I just returned from a long trip from southern Virginia to pick up a car just north of NYC . The engine ran GREAT. Super amounts of power. I never had to douwnshift once. Not even on any of the long mountians through upper PA on I-81. I was literally passing folks going up the hills with a '69 Super Bee on my trailer. But..... The gas mileage was crazy bad. I never broke 7 MPG (even with the empty trailer). But..... It had lots of power! Stan
[Re: HemiStan]
#786235
09/04/10 02:52 PM
09/04/10 02:52 PM
Suregrip
Fort Lauderdale, FL
what piston rings did you use on your build? anyone? I was looking at the KB pistons for my build.
[Re: HemiStan]
#786237
09/04/10 03:33 PM
09/04/10 03:33 PM
Suregrip
Fort Lauderdale, FL
Thanks, I am putting together a parts list now and will post it in the next few days for more input. I was also wondering of machine shop recommendations on the Eastern Shores if anyone knows...
