Re: DoctorDiff's rear disc kit
[Re: AndyF]
#783699
08/31/10 11:57 AM
08/31/10 11:57 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Yes, it is a road race car. Those are 10.7 brakes in the picture and they work just fine on a car that goes 150+ mph. The car could probably use more rear brake so we might step it up to the larger rotors.
So on a 3200lb E-body with really wide (good) tires the 11.75/11.7" brakes all around would work pretty well at speed...???
Sure wish i could fit the really big stuff under stock rims... I'd like the option ov throwing the stock rims on for a nostalgia night now and then...
[Re: Pale_Roader]
#783700
08/31/10 01:49 PM
08/31/10 01:49 PM
Posts: 31,106 Oregon
AndyF
Just depends how much power you have and how hard you drive. A powerful 3200 lb car that is being driven hard on a road race course will cook the factory 11.75 rotors really quick. If you're just cruising around the track then they'll last a long time.
We use a custom built 13 x 1.250 rotor up front on this Valiant with Baer six piston calipers. Those are $3000 brakes and even those will start to fade after repeated stops from 150. Factory 11.75 rotors up front would be toast in a few laps on a car like this.
[Re: AndyF]
#783701
09/01/10 07:21 AM
09/01/10 07:21 AM
Pale_Roader
Swears too much
Swears too much
You know, i drive my cars pretty hard. Actually no, i should say i drive them pretty fast, all the time, everywhere, but somehow i am just not hard on the brakes. I get crazy mileage out ov brakes compared to others. Even on the girlfriend's 96GT Mustang, with its 4-wheel (but very small) discs, i've only warped two sets (fronts) in 4 years, and those stock GT (not the Cobra brakes) will warp if you look at 'em hard enough...
I've got a couple cars i've owned for years and years that still have the brakes on them they came with. Sure, road racing will change the needs drastically, but i still say i'd do better than most, wear-wise. Again, the ONLY reason i wont go with bigger 13 or 14" set-ups, is so i can still use stock rims on occasion.
I'm assuming you're doing all the usual tricks with your Valiant like cooling/ducting, SS hoses, etc....??? I haven't gone that far yet, but i will with this project i'm building.
[Re: AndyF]
#783703
09/05/10 03:08 AM
09/05/10 03:08 AM
Posts: 793 Utah
topbrent
Utah
AndyF: Cass, is the Ford Explorer kit still available? Looks like it isn't in the catalog anymore. Have you used the new kit?
What catalog?
[Re: Pale_Roader]
#783704
10/01/10 09:52 PM
10/01/10 09:52 PM
Posts: 1 los angeles CA, 90015
mikoto
Hi, good day. there's just had happened to my car and ohh, i just had realized that to increase the boost of my ford i need to fix the engine i mean i need to adjust the settings. from my ford parts. ha ha ha
cheer up! mikoto | miyata ![](/ubbthreads/images/graemlins/3_2_116.gif)
[Re: gsmopar]
#783707
10/02/10 02:42 PM
10/02/10 02:42 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Do these have provision for an emergency brake, also what weight saving is there over 11" drums on my dana. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: DoctorDiff]
#783709
10/03/10 10:03 AM
10/03/10 10:03 AM
Posts: 1,560 Michigan
Kiddart
Doctor Diff do you have a web site to review the kits??
Thank you Kiddart
[Re: DoctorDiff]
#783713
05/05/11 10:26 PM
05/05/11 10:26 PM
Posts: 554 Kentucky
clovis
Kentucky
This is a pretty cost effective solution Cass put together for me. He supplied the re-drilled GM rotors and bolt on brackets. I supplied the GM Metric calipers and line kit. It requires a few little mods on the calipers but overall this is strictly a bolt on upgrade for around $300. You can get the calipers in a 2 3/8 piston, instead of the normal 2 1/2, which with the small 10.5 rotors makes the bias work out good.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#783716
05/05/11 10:58 PM
05/05/11 10:58 PM
Posts: 761 KY
juicedcuda
KY
What is the weight savings over the big Dana drums? I don't know what they weigh.
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
[Re: clovis]
#783717
05/05/11 11:33 PM
05/05/11 11:33 PM
Posts: 387 Montreal PQ, Canada
74_360_Cuda
Montreal PQ, Canada
Do you have stock front end? Booster?
