Leaf spring slider question.
#774613
08/15/10 10:50 PM
08/15/10 10:50 PM
Posts: 4,408 Madison Wi
NTOLERANCE
Madison Wi
How well do rear leaf spring sliders work in a drag application? I see them on some guys cars but many still run the oem stlye shackles.
Seems to me that the sliders would allow for better rear tire planting when the sliders reached their max forward position.
Got any real world experience? I am getting ready to install my springs, and I am thinking about going with sliders. Seems like an easier install than the shakles in the relocation kit.
I've got a 65 Coronet, 383, 4 speed, 4.10 Dana, minitubbed, springs on frame. My estimate is its a 13 sec car when completed.
Re: Leaf spring slider question.
[Re: NTOLERANCE]
#774614
08/15/10 10:55 PM
08/15/10 10:55 PM
Posts: 1,532 off the grid
340B5
off the grid
I like mine. Less separation in rear and more stability at the other end. I've done 1.62 60' w/ them.
Yeah, it's got a smallblock.
[Re: joshking440]
#774616
08/16/10 01:10 PM
08/16/10 01:10 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
When I put them on and got rid of the shackles the car didn't pick up any in the 60' but is more consistent now. It was all over the place with the shackles as far as 60' time. This is running low 1.30 60's
One day I will have something cool here.
[Re: sdaurity]
#774617
08/16/10 05:11 PM
08/16/10 05:11 PM
NTOLERANCE
Madison Wi
Good info guys. Thanks for the replies.
HOw did you weld them to the frame? They seem wider than the mopar rear frame rails.
[Re: NTOLERANCE]
#774618
08/16/10 05:20 PM
08/16/10 05:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When I've put them on I just welded them on top of the slider bracket to the rail... no big deal(make sure the rails are clean metal) and square to the spring ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#774619
08/16/10 07:06 PM
08/16/10 07:06 PM
NTOLERANCE
Madison Wi
How far fore aft?
LEt the springs hang and mount them with the slider all the way forward?
[Re: NTOLERANCE]
#774621
08/17/10 07:40 AM
08/17/10 07:40 AM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
How far fore aft?
I would like to know also ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: NTOLERANCE]
#774622
08/17/10 09:20 AM
08/17/10 09:20 AM
MR_P_BODY
How far fore aft?
Let the diff hang and set them so they just clear the front(dont want any upsets on the chassis) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: joshking440]
#774624
08/17/10 11:19 AM
08/17/10 11:19 AM
Posts: 842 Baltimore,MD
Bill_LBSR
Baltimore,MD
IIRC AFCO suggests the leaf spring eye be 3/4 of the way toward the back of the slider box.
LBSR
[Re: MR_P_BODY]
#774625
06/20/12 11:47 PM
06/20/12 11:47 PM
Posts: 3,433 Toronto
mshred
Toronto
How far fore aft?
Hey guys,
I know this is a thread brought back from the dead, but I needed some clarification on this...Mr. P., you are letting the diff hang with the slider installed on the rear spring eye and placed up to the frame? And then setting them just a hair back from the front of the slider and welding them there?
[Re: MR_P_BODY]
#774627
06/21/12 04:22 PM
06/21/12 04:22 PM
mshred
Toronto
How far fore aft?
Hey guys,
Just tack them in place then let the rear end hang to see where the bolt is on the slider... you dont want them hitting either end... once they are located right them burn them on EDIT the first time I tacked them a bit forward so I could measure how far I had to move them rearward... if yo tack them on to far rearward the bolt will hit the front and you cant get a measurement on how far to move them
Thanks for the info Mr. P. Was just trying to get an idea of roughly where to tack them in the first place with nothing to go by
[Re: MR_P_BODY]
#774629
06/21/12 09:58 PM
06/21/12 09:58 PM
Posts: 161 SE Iowa
Jonnyj00
SE Iowa
I just installed the Speedway brand on a 71 demon and looked at this info when making my decision. http://www.afcoracing.com/tech_pages/leaf.shtml I installed mine 3/4 from the rear at race weight. With fuel and so on.I beleive I got that info through moparts. Hope this helps ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MR_P_BODY]
#774631
06/22/12 01:13 AM
06/22/12 01:13 AM
mshred
Toronto
If you let the diff hang use a square off the frame rail to the center of the spring eyelet and that will give you a starting point
First off, Happy Birthday Mike! All the best to you man!
I got the sliders installed...let the diff hang, got an idea where they needed to be and went from there making sure I had enough extension and compression with them where it wasn't bottoming out. The 3/4" that everyone mentions, is that the gap that you are measuring, or from the back of the slider gap to the center of the spring bolt?
Also, I only ended up welding the sliders on the front and back as the sides are quite a bit wider than the frame...do you guys think this is strong enough???
[Re: mshred]
#774632
06/22/12 06:29 AM
06/22/12 06:29 AM
MR_P_BODY
First off, Happy Birthday Mike! All the best to you man! I got the sliders installed...let the diff hang, got an idea where they needed to be and went from there making sure I had enough extension and compression with them where it wasn't bottoming out. The 3/4" that everyone mentions, is that the gap that you are measuring, or from the back of the slider gap to the center of the spring bolt? Also, I only ended up welding the sliders on the front and back as the sides are quite a bit wider than the frame...do you guys think this is strong enough???
Thanks... I put a piece of metal between it and the frame... but that part isnt carrying that much load so it should be fine ![](/ubbthreads/images/graemlins/wave.gif)
