SB TF727 issue - lost third and reverse
#774122
08/15/10 02:37 PM
08/15/10 02:37 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
In route to Mopar Nationals, my Roadrunner broke down. We were cruising down the interstate at 60 mph or so and the transmission just downshifted to second. No sign of any slippage. Throttle linkage was set right and it seemed to have plenty of throttle pressure. No leaking and fluid looks and smells clean. Still shifts through first and second, but no reverse either. Guessing I lost a band or clutch pack. I'll be pulling the transmission this week and probably bringing it to a friend for repair, but I'm looking for some advanced pre-diagnosis.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: SB TF727 issue - lost third and reverse
[Re: dOc !]
#774124
08/15/10 03:06 PM
08/15/10 03:06 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
You probably BLEW OUT the rubber seal in the front clutch piston.... a 50 cent seal
[Re: 1_WILD_RT]
#774125
08/15/10 03:26 PM
08/15/10 03:26 PM
471Magnum
Space Station #5
So... what causes it to blow out? Mis-assembly?
Do I need to remove the transmission and tear it down to replace the seal, or can it be done in car? Got a part number for the seal?
Point me to the right page in the FSM. I'm flipping through looking for it.
-Jim
[Re: 70AARcuda]
#774128
08/15/10 07:11 PM
08/15/10 07:11 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
From this statement you made .. this trans was supposedly redone a short time ago ?
[Re: dOc !]
#774129
08/15/10 09:47 PM
08/15/10 09:47 PM
471Magnum
Space Station #5
Only owned the car about a month. PO claims it has a few thousand miles on it.
[Re: fox]
#774132
08/16/10 02:38 PM
08/16/10 02:38 PM
471Magnum
Space Station #5
Anyone else have an opinion?
-Jim
[Re: dOc !]
#774141
08/22/10 07:20 PM
08/22/10 07:20 PM
471Magnum
Space Station #5
No. It was a cast iron seal. I may have the description wrong.
-Jim
