best way to restore tail light housings #773853
08/14/10 10:00 PM
08/14/10 10:00 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I read on here not too long ago on what to use to clean up pot metal tail light housings (car in question in a 71 roadrunner if it matters) it was a certain media to use for a media blaster. and I imagine that in inside is reflectice and the outside is suppose to be dull. thanks in advance!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: best way to restore tail light housings [Re: mopars_1] #773854
08/15/10 11:15 AM
08/15/10 11:15 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
I'm not sure on media blasting. Scott on the board here (handle=ScottSmith_Harms) can help you in the area. If you send it to him, he will do a First class job on your taillights!
http://www.harmsauto.com
Ray
Re: best way to restore tail light housings [Re: mopars_1] #773855
08/15/10 04:28 PM
08/15/10 04:28 PM
Ohio
tak Offline
tak  Offline
Ohio
I did my 71 RR housing by cleaning them with Siimple Green and then respraying the inside with a Reflective silver or chrome paint ( available anywhere). Originally the inside was plated but the reflective paint works well, the are plenty brite. I have a spare set of 71 housings that were zinc dichromate (gold) in color. Eastwood sells a paint for that BUT it's not the same as real plating. You can't see them at all once on the bumper so clean them and respray the inside and be done with it..good choice of car by the way.............
Re: best way to restore tail light housings [Re: tak] #773856
08/15/10 04:44 PM
08/15/10 04:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.....probally the best way to go,...www.eastwood.com offers a lot of the reflective sliver sprays,....unless your going OEM Gold challenge,...the taillight housings are out of site once the bumper is installed,......if you send them out, they are going to cost a pretty penny to have redone,...plus it may take "awhile" for turn around, so plan accordingly...
Re: best way to restore tail light housings [Re: DAYCLONA] #773857
08/15/10 06:35 PM
08/15/10 06:35 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
any suggestions for the gold coloring on the side visible in the trunk without sending them out for plating
Enjoy life today, It has an expiration date
Re: best way to restore tail light housings [Re: gtx6970] #773858
08/15/10 08:42 PM
08/15/10 08:42 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Hello Bill,
I used Eastwood gold cad system on my taillight buckets, the side seen in the trunk.
Ray
Re: best way to restore tail light housings [Re: rayztoy] #773859
08/15/10 09:46 PM
08/15/10 09:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I like to first glassbead the surface, then apply a coat of etch primer for rust protection as the metalic paints don't yield long term protection,....I start with the crap Chrome in a can spray paint, then a crap gold in a can, then apply various shades of light purples, seafoam greens, all translucents or fine metalics from the Dupli-color spray can line to achieve the multiable colors/hues you see in a "true" plated part, all the colors listed must be applied at the same time inorder to blend them in to achieve a "plated" look of altering hues...it takes some time and effort,...often the best results are achieved by accident, or not even trying,.....
Mike
in this pic I did the tubular jack shaft, jack holddown wingnut, and side marker benzel retainer using "paint"....the chrome and gold paint help produce a plated metal look, with the very lightly applied metalic purples and metalic seafoam greens causing a distortional effect,...much like a gold cad plated part exhibits
Re: best way to restore tail light housings [Re: DAYCLONA] #773860
08/16/10 12:55 PM
08/16/10 12:55 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Hi Mike,
Nice job there!
Is this the gold and chrome you used or could you use it?
http://www.duplicolor.com/products/automotiveMetallic/
Is this the color (MetalCast) you used for the green and purple?
http://www.duplicolor.com/products/metalCast/
Thank you.
Ray
Re: best way to restore tail light housings [Re: rayztoy] #773861
08/16/10 08:04 PM
08/16/10 08:04 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Hey Ray,......Correct,..I use the Dupli-color Chrome and gold, ... to give the part that plated look, chrome as the base over a light gray etch prime, then gold over the chrome, very lightly, all wet coats, then randomly spray the green seafoam and light purple, actually rather hap hazzardly, as that produces the best results,...when you "try" to imitate the effect, that's when you make crap! ,....and when it just starts to look good, don't mess with it anymore,...the Green is a seafoam metalic, (Duplicolor) from thr GM line, and the light translucent purple is actually a Cadilac color from the GM Duplicolor line,...the line of touch up spray paints in the mini spray cans, there so translucent they proberly suck for actual touch up, but perfect for createing optical effects in the paint,....you used the Eastwood cad system,...which I've used in the past,...and as I'm sure you found that it takes a little trial and error to get nice results,...your taillights look good! ,....but the Eastwood kit was just to nuch money after a while, plus the cans liked to clog (not the tips) where they were usless,...so I started playing with other alternatives
Mike
Re: best way to restore tail light housings [Re: DAYCLONA] #773862
08/16/10 09:20 PM
08/16/10 09:20 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
but the Eastwood kit was just to much money after a while, plus the cans liked to clog (not the tips) where they were usless,...so I started playing with other alternatives
Yes Mike,
That's why I asked what you have used because I was looking at alternatives. Since my Eastwood Cad system ran out, I've been using a light grey primer-sealer. When dry, a base coat of Duplicolor silver, dusting on randomly the Duplicolor gold, and the MetalCast red & green. Thanks alot for sharing your techniques! I've learned alot from you 'MASTERS' on the board here. You guys make the hobby fun!
Ray
Re: best way to restore tail light housings [Re: rayztoy] #773863
08/16/10 11:05 PM
08/16/10 11:05 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Another option is to use Eastwood carb renew paint. Not a bad look, as long as youre not going for OE judging. I ended up using the CAD paint kit from Eastwood. I don't seem to have a picture of the end result, all I found was a the test I did with the carb renew paint.
Re: best way to restore tail light housings [Re: gygeneral] #773864
08/17/10 12:18 AM
08/17/10 12:18 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
hmm.. and all this time I thought the back sides were left in bare pot metal
1937 Plymouth PT50
Re: best way to restore tail light housings [Re: mopars_1] #773865
08/17/10 09:18 AM
08/17/10 09:18 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Here's a picture after cleaning. You can see the CAD plating
Re: best way to restore tail light housings [Re: gygeneral] #773866
08/17/10 09:23 AM
08/17/10 09:23 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Here's a pic of some tests I was doing with the Eastwood CAD system experimenting with the amounts of red and green to put on.
Re: best way to restore tail light housings [Re: gygeneral] #773867
08/19/10 07:02 PM
08/19/10 07:02 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Norm,
Thanks for sharing the pics and the paints you used.
Ray
Re: best way to restore tail light housings [Re: rayztoy] #773868
08/19/10 09:53 PM
08/19/10 09:53 PM
Ohio
3404 Offline
3404  Offline
Ohio
Actually they were not plated at all, when the casting (zinc die cast) were new they ran them thru a chromic acid which gave them the bronze(ish) color. The chromic acid was (is) used to give zinc based castings a "shelf life". It's almost impossible to clean and run a original back thru a chromic acid and get the same results/color. Age and any type of cleaning or blasting pretty much seals the casting and prevents them from being done again.You can clean them and hit them with some zinc plating so they will take a fresh yellow but it makes them a bit brighter than original.
Re: best way to restore tail light housings [Re: 3404] #773869
08/20/10 10:04 PM
08/20/10 10:04 PM
gtx6970 Offline
gtx6970  Offline
I finished a set of tail light housings for a 1970 Cuda this afternoon and they turned out great, Not OE level obviously but for a nice driver they get
Just lightly glass beaded them inside and out , refinised the inside with chrome paint and the exterior with Eastwoods carb renew. I left my camera at the shop, so I'll post pics tomorrow
Re: best way to restore tail light housings [Re: gtx6970] #773870
08/21/10 10:35 AM
08/21/10 10:35 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Painting them with an Eastwood kit will give you a decent appearance, but do the math on the cost vs a quality chemical treatment restoration before ordering a kit, it's not that much different.
In case anyone is curious, the process I use is similar to what the factory used and involves chromic acid dipping. I won't say they are 100% correct, but they are as close as I've seen anyone get so far. PM me for prices if interested. BTW, I can also do side marker housings and any other small parts with the same finish.
Re: best way to restore tail light housings [Re: ScottSmith_Harms] #773871
08/21/10 03:42 PM
08/21/10 03:42 PM
gtx6970 Offline
gtx6970  Offline
These I did because they were just plain ruff. I've got several hours in them due to all the RTV and sticky stuff done over the years to try and stop water leaks.
dis-claimer - in no way are these for an OE level car. This car IS going to be driven and driven hard. So appearence and durability is key in this particular application
What I started with
Re: best way to restore tail light housings [Re: gtx6970] #773872
08/21/10 03:43 PM
08/21/10 03:43 PM
gtx6970 Offline
gtx6970  Offline
blasted clean with fine glass bead inside and out
