best way to restore tail light housings
#773853
08/14/10 10:00 PM
08/14/10 10:00 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I read on here not too long ago on what to use to clean up pot metal tail light housings (car in question in a 71 roadrunner if it matters) it was a certain media to use for a media blaster. and I imagine that in inside is reflectice and the outside is suppose to be dull. thanks in advance! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: best way to restore tail light housings
[Re: tak]
#773856
08/15/10 04:44 PM
08/15/10 04:44 PM
Posts: 18,167 Mass
DAYCLONA
Mass
I did my 71 RR housing by cleaning them with Siimple Green and then respraying the inside with a Reflective silver or chrome paint ( available anywhere). Originally the inside was plated but the reflective paint works well, the are plenty brite. I have a spare set of 71 housings that were zinc dichromate (gold) in color. Eastwood sells a paint for that BUT it's not the same as real plating. You can't see them at all once on the bumper so clean them and respray the inside and be done with it..good choice of car by the way.............
.....probally the best way to go,...www.eastwood.com offers a lot of the reflective sliver sprays,....unless your going OEM Gold challenge,...the taillight housings are out of site once the bumper is installed,......if you send them out, they are going to cost a pretty penny to have redone,...plus it may take "awhile" for turn around, so plan accordingly...
[Re: gtx6970]
#773858
08/15/10 08:42 PM
08/15/10 08:42 PM
Posts: 1,171 Richmond, VA
rayztoy
Richmond, VA
Hello Bill, I used Eastwood gold cad system on my taillight buckets, the side seen in the trunk. Ray
[Re: rayztoy]
#773859
08/15/10 09:46 PM
08/15/10 09:46 PM
Posts: 18,167 Mass
DAYCLONA
Mass
I like to first glassbead the surface, then apply a coat of etch primer for rust protection as the metalic paints don't yield long term protection,....I start with the crap Chrome in a can spray paint, then a crap gold in a can, then apply various shades of light purples, seafoam greens, all translucents or fine metalics from the Dupli-color spray can line to achieve the multiable colors/hues you see in a "true" plated part, all the colors listed must be applied at the same time inorder to blend them in to achieve a "plated" look of altering hues...it takes some time and effort,...often the best results are achieved by accident, or not even trying,.....
Mike
in this pic I did the tubular jack shaft, jack holddown wingnut, and side marker benzel retainer using "paint"....the chrome and gold paint help produce a plated metal look, with the very lightly applied metalic purples and metalic seafoam greens causing a distortional effect,...much like a gold cad plated part exhibits
[Re: rayztoy]
#773861
08/16/10 08:04 PM
08/16/10 08:04 PM
Posts: 18,167 Mass
DAYCLONA
Mass
Hey Ray,......Correct,..I use the Dupli-color Chrome and gold, ... to give the part that plated look, chrome as the base over a light gray etch prime, then gold over the chrome, very lightly, all wet coats, then randomly spray the green seafoam and light purple, actually rather hap hazzardly, as that produces the best results,...when you "try" to imitate the effect, that's when you make crap! ,....and when it just starts to look good, don't mess with it anymore,...the Green is a seafoam metalic, (Duplicolor) from thr GM line, and the light translucent purple is actually a Cadilac color from the GM Duplicolor line,...the line of touch up spray paints in the mini spray cans, there so translucent they proberly suck for actual touch up, but perfect for createing optical effects in the paint,....you used the Eastwood cad system,...which I've used in the past,...and as I'm sure you found that it takes a little trial and error to get nice results,...your taillights look good! ,....but the Eastwood kit was just to nuch money after a while, plus the cans liked to clog (not the tips) where they were usless,...so I started playing with other alternatives Mike
[Re: DAYCLONA]
#773862
08/16/10 09:20 PM
08/16/10 09:20 PM
rayztoy
Richmond, VA
but the Eastwood kit was just to much money after a while, plus the cans liked to clog (not the tips) where they were usless,...so I started playing with other alternatives Quote:
Yes Mike, That's why I asked what you have used because I was looking at alternatives. Since my Eastwood Cad system ran out, I've been using a light grey primer-sealer. When dry, a base coat of Duplicolor silver, dusting on randomly the Duplicolor gold, and the MetalCast red & green. Thanks alot for sharing your techniques! I've learned alot from you 'MASTERS' on the board here. You guys make the hobby fun! Ray
[Re: gygeneral]
#773864
08/17/10 12:18 AM
08/17/10 12:18 AM
mopars_1
Ridgeland Wi
hmm.. and all this time I thought the back sides were left in bare pot metal
[Re: gygeneral]
#773867
08/19/10 07:02 PM
08/19/10 07:02 PM
rayztoy
Richmond, VA
Norm, Thanks for sharing the pics and the paints you used. Ray
[Re: ScottSmith_Harms]
#773871
08/21/10 03:42 PM
08/21/10 03:42 PM
Posts: 21,962 Enjoy life today, It has an ex...
gtx6970
These I did because they were just plain ruff. I've got several hours in them due to all the RTV and sticky stuff done over the years to try and stop water leaks.
dis-claimer - in no way are these for an OE level car. This car IS going to be driven and driven hard. So appearence and durability is key in this particular application
What I started with
Enjoy life today, It has an expiration date
