Who uses 16v battery
#773427
08/14/10 10:23 AM
08/14/10 10:23 AM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
Pros an cons? Im looking at powermaster battery an charger. I want something that spins motor over faster than the (2) diehards i have now.
Shawn Jennings
Re: Who uses 16v battery
[Re: SB412DUSTER]
#773436
08/14/10 12:35 PM
08/14/10 12:35 PM
Thumperdart
State of confusion
That`s what I was afraid of...........so do they make 16 v bulbs?
[Re: Forest]
#773440
08/14/10 01:28 PM
08/14/10 01:28 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
why not ? None if it's fully charged makes no difference if from an alternator or battry charger. its charged. if it's needs attention crarging between rounds you can tell with a volt meter
home of the Sox and Martin Hemi Duster
[Re: BigDog68Dart]
#773444
08/14/10 10:47 PM
08/14/10 10:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
How many volts does it really put out... like a 12v actually runs 13.2v and is there a 16v alt and reg out there
[Re: MR_P_BODY]
#773445
08/15/10 08:16 AM
08/15/10 08:16 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
at full charge my volt meter reads 18. East coast alternator makes 16volt alternators. I don't run an alternator at the moment.
[Re: MegaDart]
#773446
08/15/10 09:08 AM
08/15/10 09:08 AM
MR_P_BODY
I wouldnt mind running the added voltage for the ignition system but my engine cranks over plenty fast enough but if I did I would want the alt and reg but I'm sure they are pricey
[Re: MR_P_BODY]
#773447
08/15/10 09:17 AM
08/15/10 09:17 AM
HEMIFRED
SOUTH JERSEY
new from powermaster a alternator that's both 12v and 16v
[Re: HEMIFRED]
#773448
08/15/10 09:38 AM
08/15/10 09:38 AM
MR_P_BODY
I've never tested a alt to see how high it can put out but I know it will put out better than 15v but the problem is the regulator... need one for the higher voltage
[Re: HEMIFRED]
#773451
08/15/10 01:09 PM
08/15/10 01:09 PM
Posts: 916 SE Washington
Forest
SE Washington
Was that reply to me?
I wanted to know if the people running 16v were running 1 battery or 2? Then to verify that if they were just running 1 16 volt battery that charging between rounds was sufficient.
[Re: Forest]
#773452
08/15/10 01:34 PM
08/15/10 01:34 PM
MegaDart
The Swamp
Raisin, I ran only one battery no alternator on 2 different cars and will do so again with my Dart. First my dragster that sees very little electrical draw due to belt drive fuel pump and alky carb. Tops off in 10mins or less after driving up to lanes a few restarts and a full pull and drive back. My Top Sportsman car add nitrous fuel pump and nitrous selanoid draw, longer cool down due to race gas and got towed to and from the lanes would take 15-25 mins to full charge. Hope this helps.
