Dana 60 questions, my plan.......
#7726
12/12/03 10:19 PM
12/12/03 10:19 PM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
well, the way my car's runnin right now i dont think the 8 3/4 will last much longer. so im gonna put a Dana in it ![](/ubbthreads/images/graemlins/devil.gif) here's what im planning..... get a Dana 60 from the junkyard, will probably have floating axles strip it down, get a new spool, bearings, and gear set weld on my old 8 3/4 axle ends....so i can reuse my original brakes and 35 spline axles from the 8 3/4 im gonna make the DANA the same width as the 8 3/4. i guess my biggest question is will my axles work??? having them cut down and resplined is no big deal, but does the dana have a weird offset axle length or anything? im thinking since its gonna be the same overall width and itll have a spool that the axles should work. am i on the right track???? thanks, CHIP
Re: Dana 60 questions, my plan.......
[Re: an8sec70cuda]
#7727
12/12/03 11:12 PM
12/12/03 11:12 PM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
Chip, sounds like a plan, that was what I planned to do when I put the dana in my car, made it the same width as my 8 3/4, but the axles would not work, I had a set of strange in mine, and they are broached on the ends, the strange brand cannot be cut and resplined, most other ones can be if they are not a broached set of axles, if you have moser, or some other brand, they can be cut and resplined, that's what I put back in mine was a moser, cut the housing, put new ends on, had all the brackets welded, new spool, gears, bearings, wound up with just a smidge under a grand invested in it, go for it, you csan'tgo wrong, by the way it picked my car up, .005, in the 1/8. go figure, and there is only a 27 lbs, difference in wt., at least that's what mine was. Thanks Dave
[Re: STEFF]
#7730
12/12/03 11:22 PM
12/12/03 11:22 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Steff, I don't want to answer for him, but IF he does have 35 spline, they would have to be aftermarket, because as you say, stock was 30.
[Re: 69RR383]
#7732
12/13/03 12:53 AM
12/13/03 12:53 AM
an8sec70cuda
thanks for the replies yall. yep, like my dad said, these are 35 spline Mosers in my 8 3/4. so everything will work, ill just have to have my axles cut and resplined as necessary. the Dana 60 ill be getting will most likely come out of a truck from the junkyard. no problem doing the narrowing and welding on it, ill get that done. ill make it the exact same width as my 8 3/4 so my rims will still have the same clearances. they're right where i want em as of now.
do yall have a general estimate on what Moser would charge to modify my axles??? thanks again, CHIP
[Re: an8sec70cuda]
#7733
12/13/03 01:05 AM
12/13/03 01:05 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Dana axles are 1-1/4" or so different in length. I bought a set of moser axles for the dana I'm doing like you and they are equal length. So one will get cut to compensate.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#7734
12/13/03 04:41 AM
12/13/03 04:41 AM
chip, you wont have to cut the axle shaft, just have to get the pinion offset right. get ahold of dr.diff, he's an expert on this!
[Re: an8sec70cuda]
#7735
12/13/03 08:15 AM
12/13/03 08:15 AM
Posts: 1,629 pa
572charger
pa
10sec, there is no place to put a pinion snubber if you are useing leafs??
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: 572charger]
#7736
12/13/03 10:45 AM
12/13/03 10:45 AM
Posts: 1,771 St.Clair Shores MI.
tilt
St.Clair Shores MI.
Chip what Dusterjohn said. Are you still running CalTracs? I just had my Truck axle set up like this. Jeff
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!)
03 Mach1
[Re: tilt]
#7738
12/13/03 10:02 PM
12/13/03 10:02 PM
an8sec70cuda
Dusterjohn....so i dont have to cut the axles down? sounds good to me. 572charger.....i dont use a snubber. back when i had SS springs the car 60 footed .05 better w/o it. Tilt....yep, still got the Cal-Trac setup on it. TonyS451.....well, i have thought of that, but i think i can come out pretty good doing it my way, and ill know the job is done right. dont get me wrong, i know some companies do great work, but if I didnt put it together or personally know the guy that did, i dont trust it. preciate the help yall ![](/ubbthreads/images/graemlins/beer.gif) CHIP
[Re: an8sec70cuda]
#7739
12/14/03 10:25 AM
12/14/03 10:25 AM
Hey CHIP,
Copy Cat .... I'm putting in a DANA as well. I have a guy who has a NEW DANA housing, tubes and brakes for $600. However, Once I spec it out, adding parts, setup and axles, it's within $100 to just get a Strange Unit ready built and delivered. That's what I'm doing.
Moser has a prebuilt housing for $1550ish, it's $85-95 to cut and respline IIRC. I'm keeping my 35 spline MOSERS for use on the 8.75" if it ever goes back for normal streeting use. I'm pretty sure MOSER said both axles would have to be modified. On my stock width, that meant ONE might not be long enough due to the offeset.
[Re: an8sec70cuda]
#7742
12/14/03 04:39 PM
12/14/03 04:39 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Do yourself a BIG favor...don't cut your 8 3/4 ends off and reuse them.Buy a set of new housing ends,you'll be much happier when it comes time to weld.
[Re: Chris2581]
#7743
12/14/03 04:58 PM
12/14/03 04:58 PM
tilt
St.Clair Shores MI.
Competition engineering sells the new ends for the mopar car type. Jeff
03 Mach1
[Re: tilt]
#7744
12/14/03 05:03 PM
12/14/03 05:03 PM
an8sec70cuda
we've reused old axle ends MANY times w/ no problems. thanks for the info though.
well, i reckon ill wait and talk w/ my chassis fab friend and see what needs to be done about the axles. obviously i'd like to get by w/o resplining the axles, but if it has to be done, so be it.
im gonna stop by the junkyard tomorrow on my dinner break and find a rearend. then go from there....
oh....one more question.....are all Dana 60s the same? i mean do they all take the same bearings, gears, and spools??
thanks yall, CHIP
[Re: an8sec70cuda]
#7745
12/14/03 06:29 PM
12/14/03 06:29 PM
tilt
St.Clair Shores MI.
Better check the man,DR. Diff. Btw i paid $ 150 for my donor out of a 72 ford P.U. and it already had a 4.10 in it.
Jeff
03 Mach1
