Drum brake keeps getting tighter and tighter(pic added)
#773390
08/14/10 09:42 AM
08/14/10 09:42 AM
Posts: 571 central PA
mopartial
central PA
75 A-body 7 1/4" rear original drum brake. 10" I think. Keeps getting tighter, now I'm driving with brake applied. I backed off on adjusters a coupla weeks ago so drums would turn freely. Now has tightened up badly again.
Why is this happening?
If it aint broke, dont break it.
Re: Drum brake keeps getting tighter and tighter
[Re: pacifica]
#773392
08/14/10 12:38 PM
08/14/10 12:38 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I agree sounds like adjusters are backwards.Most times the arms are marked left and right.Just remember left is drivers side.Rocky
Chrysler Firepower
Re: Drum brake keeps getting tighter (see pic)
[Re: therocks]
#773393
08/25/10 01:00 PM
08/25/10 01:00 PM
mopartial
central PA
I will try to post pic. Looks correct to me. See anything wrong? Drum was LOCKED.
Sorry image rotated 90*. This is driver side. No problem on other side.
[Re: Pntastar69]
#773395
08/25/10 03:04 PM
08/25/10 03:04 PM
therocks
Niles , Ohio
If it was the hose both would be locked as its the rear and both feed off the same hose.Check the adjuster and make sure its a L.Been a while since I played with them.Rocky
Chrysler Firepower
[Re: Pntastar69]
#773397
08/25/10 05:54 PM
08/25/10 05:54 PM
Posts: 75,027 U.S.S.A.
JohnRR
U.S.S.A.
Mmmm, aren't they split to each side from the brass dist block mounted on top of the rear?
Yes they are , but fed by a single hose, wit hthat in mind even though the left is closer to the dist block eventually the pressure would build and hold them both open .
Is the adjuster adjustment changing or are you havingto push the shoes back together ? Also how about a better picture ?
[Re: Pntastar69]
#773398
08/25/10 06:01 PM
08/25/10 06:01 PM
therocks
Niles , Ohio
Steel line to the whl cyls from the block.From what he says its the adjuster getting tight.If the line was collapsing it would pressure both.The little difference in length of the steel lines really wouldnt matter.Rocky
Chrysler Firepower
[Re: dirtybee]
#773400
08/25/10 08:58 PM
08/25/10 08:58 PM
mopartial
central PA
Thanks for replies.
It is the adjuster ratcheting tighter and tighter. I am back together now and rolling along nicely. Wanna drive it some before weather gets ugly. If/when it tightens again I will check for free movement of that cable, and try to post a better pic next time.
