{{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}} More Questions
#772585
08/12/10 07:39 PM
08/12/10 07:39 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Anyone have one or know who might have one in stock.....I have ck'd a few sources and the MP unit is on national back-order with know delivery date..... Thanks in advance, Rickster
Re: {{{{ RIGHT ANGLE OIL FILTER ADAPTER }}}}
[Re: MR_P_BODY]
#772590
08/13/10 12:45 AM
08/13/10 12:45 AM
Posts: 15,487 Florida
scratchnfotraction
PM sent rickster you can allways drill it to 1/2" and massage the 90* turn and gasket match it along with all the other oiling mods to the oil pump and rear main cap and drilling the 9/32 oil galleys...well you know.. i got the 9/32 drill bit and the short 1/2 drill bit..just dont have the 10-12 inch bit for the deep one to the oil filter 90* the last one i did,i spent most of the time in the 90* the fliter plate and removeing the cross section of the factory drill bit end flukes man the things you can do with an angle grinder and a dremal tool and about an 18 pack of miller light I had about 40 hrs in the home gasket match,home pocket port,block stress relieveing did the main webs and all to the oil gally and return holes opend up herb and hensleys little blue book,I wish I could find another copy of it all I gots left is a rag with herbs oil mods on a 360 left
[Re: justinp61]
#772591
08/13/10 08:33 AM
08/13/10 08:33 AM
Posts: 660 San Diego
formula S
San Diego
There was a couple for sale in the A engine section. I had trouble getting the gasket set for mine.
I just bought two kits from our local Dodge dealer part# P5249320 oil filter adapter gasket kit. try here http://www.mopartsracing.com/parts/a.html
[Re: formula S]
#772592
08/13/10 10:45 AM
08/13/10 10:45 AM
rickstershemi
Been there done that.....anyway I've decided to just pick up the stock plate and fitting for now and may go with either a moroso or canton remote setup down the road....right now I just need to get the moder primed and the lifters pumped up.
Rickster
[Re: rickstershemi]
#772593
08/13/10 11:24 AM
08/13/10 11:24 AM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
my warehouse has one in stock #DIRP5249624, $160 plus shipping. your clamps are on their way, bill you after i get back from nats, http://www.tdperformance.com/products/?id=3314 this is what i'm using on my 340, $62 +, dean
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: rickstershemi]
#772596
08/23/10 02:47 PM
08/23/10 02:47 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Big round gasket ( obvious..lol) against the block and adapter plate, small metal cored gasket under the head of the bolt, cork gasket at end of bolt, but UNDER the plate, so it seals between the plate and the block.
RIP Monte Smith
[Re: CompWedgeEngines]
#772597
08/23/10 02:49 PM
08/23/10 02:49 PM
rickstershemi
Thanks I have the cork one and the large one, now to dig up the metal one
Rickster
