Re: alternators
[Re: mopar dave]
#772188
08/12/10 03:59 PM
08/12/10 03:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run a 85 amp Denso that uses a external reg... that should be enough for you..... add up all of the draw(head lights are about 14 amps) and then add about 15% more for the size alt you would need
Re: alternators
[Re: mopar dave]
#772191
08/12/10 04:10 PM
08/12/10 04:10 PM
MR_P_BODY
looks like my draw would be 46amp + 15% would be 53amp. just called a local starter alt. shop,they have a 120amp denso with external reg. for $200 brand new. what do ya think?
With 120 amps you can run a train... ask them what it puts out at idle
Re: alternators
[Re: mopar dave]
#772193
08/12/10 04:38 PM
08/12/10 04:38 PM
MR_P_BODY
ok, i'll go take a look at what he's got and if something less than 120amp.
Dont get me wrong... 120 will work fine and if you decide to up the radio with a couple of big amps you will have enough power just see what they put out at idle
Re: alternators
[Re: mopar dave]
#772195
08/12/10 07:24 PM
08/12/10 07:24 PM
Posts: 583 Raleigh, NC
rockerbob
Raleigh, NC
I see where Eastwood ( the auto restoration folks) is selling a nice NEW alternator. $199.99 GM 1 wire style. Apparently catered toward street rods & cruisers. They have a nice video on their site explaning the benefits of it. Check it out before you buy. It may work for you.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
1969 Satellite 318 "bracket racer"
1966 Barracuda (in progress )
1964 Dodge 330 (future race project)
1962 Belvedere (HUM????)
Re: alternators
[Re: mopar dave]
#772199
08/12/10 09:21 PM
08/12/10 09:21 PM
Posts: 7,506 Az
Crizila
Az
First thing you need to know is how fast you are spinning your existing alternator @ idle. Crank pulley Dia. divided by the Alt. pulley dia. = pulley ratio. Pulley ratio X idle rpm = alt. rpm @ idle. You may not be spinning your existing alt. fast enough at idle, and installing a higher amp output alternator may not necessarily solve your problem. Which ever alt you buy, see if you can get it with an amp output curve. Most drag race alternators have a very fast rise time - lots of amps at low rpm's. What you are looking for is a combo ( alt.& pulley )that will cover your amp load @ idle - and no more. More than that is a waste of HP. BTW, most of the HP loss is in spinning the cooling fan, not in amps. It can be a real "catch 22" if you are trying to do double duty - street and strip. When you get the alternator spinning fast enough to cover all your accessories at idle, at 6500 engine rpm the alternator is spinning over 20K. The rotor usually doesn't last too long at those speeds. Some typical alternator numbers: Max speed for an alternator = 18,000 rpm. They usually reach max output around 6,000 rpm. Alternators perform best from 2,400 - 6,000 rpm with greatest efficiency around 2400 rpm. Sustained alt. speed of 14,000 to 18,000 wastes lots of HP. Also keep in mind that many of the high output ignition systems around these days are "happiest" at 14 volts. They aint high output at 12 - 13 volts.
Fastest 300
