Re: 72 duster drum brakes
[Re: bboogieart]
#771762
08/12/10 12:47 PM
08/12/10 12:47 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
ten inch drums were used for many years after his car was built. Don't ask for the year car just the brake parts you need, they are out there and common, maybe tell the kid behind the counter it is a 85 truck with 10" rear drums. Basically the parts are not discontinued but that year is off the books.
Sorry , incorrect , 72 was the LAST year for the 5 on 4" bolt pattern so finding drums is not going to be as easy as you suggest.
This car will have 10" rear drums if it has a v8 with drums all around or if it has front disc brakes, engine size doesn't matter with disc. If you find the drums newthey will not the the BELLED drums as that car will have but they will still fit and work fine .
