intake manifold design
#771473
08/11/10 02:15 PM
08/11/10 02:15 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It's been a while since I read Corky's book so I don't remember all the ins and outs of EFI manifold designs.
Fred has a tunnel ram and plenum design for his monster motor. Most guys use a typical 4 bbl intake with a throttle body. Others use a round throttle body on a 90* neck for a carbed style intake.
How do you determine the best manifold for your EFI engine? I know the long runner intakes are popular on the late model engines but what size plenum are they using?
My intake is a Weiand tunnel ram with a 390 cubic inch plenum on top. Is that better suited to street use, track use, or what?
Re: intake manifold design
[Re: feets]
#771480
08/12/10 10:46 AM
08/12/10 10:46 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
going to make something Feets?
I already have:
![](http://image.popularhotrodding.com/f/8898893+w750+st0/0711phr_13_z+1965_plymouth_belvedere+engine.jpg)
My mind is just wandering a little. A
n idle mind is a dangerous thing.
looks like that started life as a tunnel ram.
[Re: furious70]
#771484
08/12/10 06:44 PM
08/12/10 06:44 PM
Posts: 2,175 Duloc
The Shadow
Duloc
I believe your reading into this too much if it's for a boosted application. ![](/ubbthreads/images/graemlins/Twocents.gif) Just look a roots manifold.
[Re: feets]
#771486
08/13/10 10:25 AM
08/13/10 10:25 AM
Posts: 1,417 Chicago, IL
blownEFI
Chicago, IL
Street car vs. Race car makes a difference. Force inducted race car doesn't care too much about intake design as has already been stated in this thread. However, a street car is not on boost 99% of the time and therefore behaves the same as naturually aspirated, so manifold design will have an affect on driveability. If you only care about WOT HP on boost then slap on any ole thing you want and it will probably function.
"These go to eleven", Nigel Tufnel
[Re: blownEFI]
#771489
08/13/10 07:30 PM
08/13/10 07:30 PM
Posts: 2,175 Duloc
The Shadow
Duloc
I really can't agree on this theory The car will drive around just fine with efi as it's tuned with the map/fuel. It might not be optimal but it works. I would think converting a single 4 manifold over a tunnel ram proves my point. With the unequal runner length and usual poor fuel/air distribution characteristics and issues they still work. An equal length runner intake should blow it out of the water but the don't seem to. Show me a factory F.I. manifold with unequal runners ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: The Shadow]
#771490
08/14/10 01:56 AM
08/14/10 01:56 AM
DaytonaTurbo
Manitoba, Canada
Modern factory boosted efi cars are designed around providing fuel economy and passing emissions standards. They aren't designed with race-only in mind. I would still say that a crappy 4bbl intake is still going to perform lousy on a boosted vehicle if anything just from air/fuel variations from cylinder to cylinder. I think you at least want a reasonable intake.
[Re: DaytonaTurbo]
#771491
08/15/10 11:13 AM
08/15/10 11:13 AM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
another thing to keep in mind is that most of the manifolds we can get our hands on for the older engines are/were/ designed for "wet flow" applications. I would venture to guess even the ones with efi bungs cast in them still were designed with wet flow ideals. For efi, we have to think about dry flow before the injector. You want some turbulence before the injector to start the mixing, and good velocity. But, the problem is, when you throw boosted flow velocities in the mix its tough to get all that, plus good injector targeting with the older intake openings. Just look at a modern engine and how the intake port has injector openings to help direct the flow at the back of the valve. I know on my EFI 383, you can see the clean spot on the opposite side of the intake port (bottom) from where the injector spray is hitting. Most likely at idle low flow conditions. If I could do it again, I woul look at a short tunnel ram with the injectors underneath to try and adjust that angle.
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
[Re: feets]
#771492
08/16/10 08:30 PM
08/16/10 08:30 PM
Posts: 42 SE PA
Five9Dak
SE PA
I'm going to see how the modman works with a twin screw sitting on top of it. The runners are short fat and have nice radiused (almost bellmouthed) entries right out of the box.
For a max effort centrifugal application a plenum box on top of the modman might be pretty nice. Stree manners would be pretty terrible I bet though.
