Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: BradH] #771424
12/12/10 05:39 PM
12/12/10 05:39 PM
Chickamauga,Georgia..U.S.A
SuperStock426 Offline
I installed the 1009 Fel Pros on my 10.62:1 440 with Edelbrock heads..I did not re torque the heads and ended up blowing a head gasket at #8 cylinder..I am replacing them with the 8519's..So I would recommend retourqing after you put some miles on your engine..
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: 5spdcuda] #771425
12/12/10 10:23 PM
12/12/10 10:23 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
They will probably work, but I would use the 1000 series gaskets with aluminum heads. They are what Edelbrock recommends and I use them on my small block. Trouble free after 40,000 miles.
When you order the Edelbrock B/RB head gaskets,they are 8519PT's in the package.
Nautilus Racing-
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: Chris2581] #771426
12/12/10 11:51 PM
12/12/10 11:51 PM
Has anyone else had the same problem of blowing a head gasket on a big block from not retorqing when using the Fel Pro perma torques?
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: SuperStock426] #771427
12/13/10 01:10 AM
12/13/10 01:10 AM
Not me,I have reused both of the Fel pro numbers listed on here. I did blow a pair of the 1009 due to the fire ring hanging into the combustion chamber Check all things during assembly carefully before getting after the tune
Re: Max safe CR for Fel-Pro 8519 PT-1 bb head gasket? [Re: Cab_Burge] #771428
12/13/10 11:01 AM
12/13/10 11:01 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Not me...
Me, either, with the 1009s. I haven't run the standard Perma-Torque in so long that my experiences weren't on anything remotely like I'm building now.
