Page 3 of 3 1 2 3
Re: Get out of it's own way - 340 RR [Re: FuryBoy] #771392
08/13/10 10:40 PM
08/13/10 10:40 PM
P
Paul_Fancsali Offline
P
The point I'm making is most big blocks of that era 73-75 suffered more power loss then the equvalent small block. a 340 was rated 275 hp a 440 same year was 375 |In 1973 they were 340 net 240 and 280 net 440. That is big diff.I own a 1973 360 low comp is it fast no, but it will run low 14s all day long and it was rated 175 net hp.It will hold 4000 rpm for hours and run on mid reg. This is in a car that weigh's 4260 racing weight.
Re: Get out of it's own way - 340 RR [Re: FuryBoy] #771393
08/13/10 10:57 PM
08/13/10 10:57 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
There is always somebody faster....
Not always...
Re: Get out of it's own way - 340 RR [Re: Challenger 1] #771394
08/13/10 11:14 PM
08/13/10 11:14 PM
Eugene, OR
FuryBoy Offline
FuryBoy  Offline
Eugene, OR
there is when were talking about street cars.
I use to think my mom's '66 Pontiac Catalina was fast... It makes me laugh anytime I drive it now, but it's still a nice car, just not fast.
Re: Get out of it's own way - 340 RR [Re: Paul_Fancsali] #771395
08/14/10 12:37 AM
08/14/10 12:37 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes, but you conveniently omit the fact that in 73 the 440 had almost 100 more ft-lbs of torq and at a lower rpm. In two identical 73 RR's with the same converter, trans and gears, the 440 car will win. The extra torq at a lower rpm will perform better with the stock torq converter and give the oomph you need to get that heavy car moving.
If you're comparing a hi-cr era lightweight 340 a-body to a smogger low comp 73 440 b-body you are NOT comparing apples to apples.
To the OP, a turbo or supercharger setup would make your 340 feel like a totally different animal. If you want to do something fun on a budget, you can pickup a used centrifugal supercharger like a paxton sn2000, sn93 or sn89. They are perfectly sized for a small block and don't go for that much $$. Pop in that 268 cam, do a set of headers, intake, carb and that supercharger and you could be in the 350-400hp zone easy while giving you the bottom end torq you need.
Re: Get out of it's own way - 340 RR [Re: DaytonaTurbo] #771396
08/14/10 12:45 AM
08/14/10 12:45 AM
Tulsa, Oklahoma
Wagonmaster Offline
Wagonmaster  Offline
Tulsa, Oklahoma
This really is not meant to be too much, but one of the more fun cars I had was a bone stock '73 GTX. Looked a bit rough, but was absolutely a virgin.
Put a battery in, repaired the radiator, a quick tune and I was VERY impressed.
'73 GTX B-body w/440 stock. The reason my wife wouldn't ride with me in a toy car again. Long story, but very decent car.
Your 340 car could eat up lots of coin making it close to a 440 compatible car.
Save the aggrivation, stuff a 440 in it, save the 340 and save lots of $$, too!
Just my
Re: Get out of it's own way - 340 RR [Re: Wagonmaster] #771397
08/14/10 11:26 AM
08/14/10 11:26 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
A pair of magnum heads could wake it up quite a bit in the air flow department and compression and the 1.6 ratio rockers will make the cam work like it is slightly bigger. Make sure you use the thin head gaskets and you WILL notice a differance. You can get stock re-built heads from flea-bay for a couple hundred bucks, have them re-drilled at a local machine shop for under $100 (If you were close by I only charge $50), buy a gasket set, conversion pushrods from mancini and be done, then you can keep you stock short block in the car and it will make more power than a 68 340.
Re: Get out of it's own way - 340 RR [Re: HotRodDave] #771398
04/10/11 09:51 PM
04/10/11 09:51 PM
North Florida
RebelDart Offline
super street
RebelDart  Offline
super street
North Florida
What years for the heads would be recommended - finally on the road and as expected --- not impressive .............. yet.
Re: Get out of it's own way - 340 RR [Re: RebelDart] #771399
04/11/11 02:32 PM
04/11/11 02:32 PM
P
P
Cheap a set J heads with 2.02 valves or the stock 360 heads with 2.02s Set your timing to have it all in by 2000 and total near as possible to 44 degree if the engine can take it.Use a 180 stat the 160 in that engine will cost you time except on a very hot day By the way a set of thin head gaskets will help in the power dept and headers are a must unless you have the early exhaust manifolds then use a 2.50 max pipe, and set of cutouts
Re: Get out of it's own way - 340 RR [Re: RebelDart] #771400
04/11/11 03:37 PM
04/11/11 03:37 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
junkyarding, '92-01 318's or 92-02 360's....
while yarding, get the retainers off of some 2.2L/2.5L mopar 4 bangers, and buy some hughes #1110 valve springs.
or if you don't want to go through the hassle, buy these new enginequest 318B heads with LA bolt pattern, #1110 springs and new OEM spec valves. should flow ~ 10% better than OEM magnum heads. I'd also pick up a comp XE256 cam while you're at it.
2017 Grand Cherokee Overland
Re: Get out of it's own way - 340 RR [Re: patrick] #771401
04/11/11 03:48 PM
04/11/11 03:48 PM
Kirkland, Washington
Pacnorthcuda Offline
The FIRST thing I would do is find out what gear you have in that thing. IF its something like 2.76 or 2.94 THEN a swap to 3.55's will make a BIG difference. If its 3.23 or higher (numerically) THEN look elsewhere!!!!!
Truer words never posted.
Re: Get out of it's own way - 340 RR [Re: Mr.Yuck] #771402
04/11/11 04:09 PM
04/11/11 04:09 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I don't think abody is saying that at all. But a stock 340 vs a stock 440 in the same car the 440 wins. A mild 340 vs a mild 440 in the SAME car the 440 wins. Just like if you put a 440 in an a-body and a 340 in the other, they have they same build a little cam, compression, gear, intake carb, the 440 WINS. Jeesh.
Of course; any one suggesting otherwise is
You can't have a 100 cubic inch disadvantage on similarly built motors and not have a significant performance difference.
My cousin's 340 Duster was one of the fastest cars I've ever driven but at 14.5:1, solid lifters, etc, etc, it was FAR from stock!
Re: Get out of it's own way - 340 RR [Re: Pacnorthcuda] #771403
04/11/11 04:10 PM
04/11/11 04:10 PM
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Page 3 of 3 1 2 3
