Re: Dyno'd my 440 and was disappointed - Questions question
[Re: NOrrTH]
#770006
08/10/10 09:00 PM
08/10/10 09:00 PM
Posts: 571 Beaverton, OR, USA
Alikazam
super gas
super gas
Beaverton, OR, USA
Again, thanks for all the excellent advice and comments. Some people say that the numbers are about where there should be given the limited info I have and that gives me the comfort I was looking for.
Soooo.... it turns out I had a dead plug. Wouldn't that of shown up on the dyno's computer? Not sure how much a difference that would've made, but ya, there's some lost hp ![](/ubbthreads/images/graemlins/tongue.gif)
To answer some of the questions:
The dyno numbers are uncorrected 83 deg F 33% humidity elevation 103 ft max hp at 4500 rpm max torque 3750 No the dyno guy didn't tune it, just fluids Air fuel line is almost flat after 3k rpm at 13.5
My cousin said "throw on some 906 heads, put 3.91's in it and that will wake that 440 up."
The car goes pretty good, I'm not complaining but..another 75 or so hp would be nice
I would definitely "re-dyno" after fixing the dead plug. There is no guarantee the operator would catch a choppy idle with a miss, it could be chalked up to a radical sounding cam and as you went higher in the revs, yo might notice a miss, but usually on a chassis dyno it gets pretty loud so it could have been missed. That being said, I am a fan of both Chassis Dyno results and 1/4 mile results. Mine tend to agree, but I have been to a chassis dyno where the operators were new at it and had their setup "way off" but swore up and down that my engine was making 40 less rwhp from the week before after only swapping out spark plugs... when later it was found out that they had the dyno in AWD mode not 2wd mode... *shrug* Take it all with a grain of salt I say but I would drag race it (and MPH is the best indicator given a "decent" launch) and dyno it and just enjoy the hobby! The last dyno operator was very impressed with my very street friendly 340 rwhp/349 rwtq 360. He said a lot of big block cars in his shop make less than that, haha. Course, then I added the Nitrous.... *grin* Anyway, have fun, that's what its all about! You can always add a little squeeze to the fo-fo-ty if you need more out of it from time to time!
[Re: NOrrTH]
#770007
08/10/10 10:27 PM
08/10/10 10:27 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
one candle out will hurt a ton. I think I ran a 12.58 on a usual 12.teen when I burned a plug wire. 906's are ok but it depends on the port work. fix the bad cylinder and roll. 3.91's are great for a b-body auto.
[Re: NOrrTH]
#770008
08/10/10 10:50 PM
08/10/10 10:50 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
If you can take that car to a track ( find out what it weights) get the mph. And you can get a pretty good idea of the power.
And E/T is not what tells the story on horsepower, MPH is.
As important as this is, many don't understand this.
279 uncorrected hp with a dead or half dead cylinder - that is not bad. Tune it, get it to the track and have some fun, and then tune some more. If you want to get serious about tuning based on mph, get a weather station.
[Re: BSB67]
#770009
08/10/10 11:49 PM
08/10/10 11:49 PM
Posts: 1,261 ILL
mark7171
ILL
You can buy a package that is known to make such and such amount. My choice was a Stage one HugesEngines Stage 1 440 Block, Heads, Cam, ported intake. The level 1, made the flywheel numbers in the range that I was going to drive. A package system be it Edelbrock Performwer /RPM/ Torquer II, or Holley systemax, and Mopar performance crate engines. The intake should be 40-60 % greater runner /plenum volume than the heads. The performer edelbrock or Wieand 8009 would work well with the stock ported heads. The runner volumes would match and package up. My daily driver was a wild card build, had a 323" w/ 318LA 1.88"/1.60 valve heads shaved to 8.5:1 compression. A 340 hp cam .430/.444" lift , single plane streetmaster 318 intake kept port size continuity, Holley 600 topped it off, Summit headers, and a 4 speed 833 with 3.23 gears. Made 237 RWhp and ran the quarter mile with a 4.10 gear centersection in 14.80's. Type 3800lb race wt 4 door valiant. The hughes Feels like it makes what the chart tells. ![](http://www.hotrodders.com/gallery/data/500/medium/22891my_Hughes_440_S1_w_RPM.gif)
[Re: feets]
#770010
08/11/10 12:09 AM
08/11/10 12:09 AM
Posts: 10,240 Someplace you aren't
SomeCarGuy
imho...
Dyno numbers are BS. 1/4 mile times are the true judge...
I agree. Take it and get some timeslips, then start looking for more power.
You guys are full of crap. What should a 3800 lb car with 459 rwhp and 490 rwtq run? That puts it close to 600 hp at the crank.
How about a 12.49? Add a converter and it'd be a solid 11 car. The dyno won't see the converter.
We recently had a dyno day with our club. A couple mild 440s made similar power to the original post. In fact, a couple small blocks were in the same park with power but were lacking the torque.
The dyno can tell you a lot about your engine. In fact, Stumpy found that he needed to try a different shift point with his truck.
A dyno is a tool. It is not a competition. When used properly, it will help improve your drag strip experience.
When there is no drag strip close or if you're not a drag racer, dynos can come in handy for tuning your car.
ET isn't what to look for. MPH tells you what it is making. Using the weight of the car and that MPH number will give you a decent "chassis dyno" number right there.
[Re: NOrrTH]
#770011
08/11/10 09:42 AM
08/11/10 09:42 AM
Posts: 37 MI
Jerseyboy
MI
13.5 is a little leaner then I like to see. I"d consider fattening it up a little and see if she likes it. You might pick up a little hp with a richer AFR. All depends on what your combo wants though..
[Re: NOrrTH]
#770013
08/11/10 02:41 PM
08/11/10 02:41 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
From the power peak RPMs, it looks like the cam is fairly small, or may even be a stock cam? A larger cam should help reduce the fuel octane requirement and add some power. With aftermarket Aluminum heads and the larger cam (plus intake and carb), you can get that extra 75 hp pretty easely, and it will tolerate lower octane fuel.
[Re: 451Mopar]
#770014
08/11/10 03:49 PM
08/11/10 03:49 PM
Posts: 1,185 Nanaimo, BC
NOrrTH
Nanaimo, BC
Unfortunately, if I want to keep my air grabber, I'm stuck with the Edlebrock Performer 440. Its an inch higher at the back than stock and I had to put a thinner air filter on to get the air cleaner lid to clear the air grabber box.
From what I've read so far on this board, it would seem that these aluminum heads are the way to go. Is that something you can buy and bolt on without knowing what pistons/compression you have? Not that I would dream of doing the work myself but if I see a good deal, maybe I can jump on them. Or maybe my intake is "not much better than stock" then they wouldn't flow so there'd be no point.
'71 GTX N96 auto 3:55
'74 Challenger 440+6 4spd 4:10
'71 Duster 340 auto 4:10
[Re: NOrrTH]
#770015
08/11/10 05:34 PM
08/11/10 05:34 PM
Mr.Yuck
Brookeville, Md
no need for aluminum heads. and a CH4B is a better intake and it will fit under the air grabber. if your power stops at 4500, that's the problem. heads won't help. Many guys run 500hp+ on old iron heads. Either you have a timing/tuning issue or it's factory cam. Although a factory cam should not have a rough idle. You need to get some compression numbers 1st. Then have a knowledgable MOPAR guy help you tune it. Then decide on what parts you want to change out. A cam swap can do wonders. Also go drive it. nail it from a dead stomp and go thru the gears a few times. Even a stock 440 w/ 3.23 gears should boil the hides mid way thru 2nd.
[Re: NOrrTH]
#770016
08/12/10 12:08 PM
08/12/10 12:08 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The Performer 440 is an aluminum copy of the factory intake. It's not considered an improvement. I ran one of those thihgs years ago.
[Re: Mr.Yuck]
#770018
08/13/10 03:57 AM
08/13/10 03:57 AM
451Mopar
Aurora, Colorado
I agree the cam is either fairly small, or way too advanced. Good heads will help, and old iron heads can make good HP, but not in stock form. I mentioned the aluminum heads because the Edelbrock Performer or 440 Stealth heads are an easy and affordable bolt on. Price out the cost of rebuilding stock iron heads with labor, the larger valves, hardened seats, new valve guides, and porting and you will have as much money invested in them as if you just bought the new heads, and the aluminum heads have closed chambers and are less prone to detonation. If you consider a stock unported heads usually only flows about 235 cfm @ 0.500" lift, and on out of the box stealth head flows 270+ cfm, that extra 35 cfm can be worth 70+ HP as long as the rest of the intake/carb/cam/exhaust don't choke the engine.
[Re: Mr.Yuck]
#770023
08/13/10 10:50 PM
08/13/10 10:50 PM
Posts: 1,261 ILL
mark7171
ILL
"The 440 performer is much better than a CH4"
no it's not. I think you are thinking of a Performer RPM, that is a totally different intake. CC or MM did an intake shoot out and the CH4B did very well even stacked against the new designed intakes.
Looking here at the picture side by side. You should be able to tell the performer 440 has more pad and plenum height. Once divided the Performers runners are longer, wider, taller, faster , stronger...
Timing, dead spark plug, and you ran it out on the dyno?
packages take out the guess work. Use them.
The CH4 intake is a great intake with a AVS carb, mild cam 440 2.76-3.23 gears.
[Re: Crizila]
#770024
08/13/10 10:50 PM
08/13/10 10:50 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Obviously your numbers are down, so something is amiss somewhere with your combo.
I'll bet it's the size of his fuel line...
I was gonna say that, but thought I'd just wait for you to chime in.
Good to see you still hanging around, John... ![](/ubbthreads/images/graemlins/biggrin.gif)
