Re: Which Mig welder????
[Re: Jeepmon]
#769610
08/09/10 02:57 PM
08/09/10 02:57 PM
Posts: 179 Auburn, Indiana
The Duster
Auburn, Indiana
I'm just starting too, but after a lot research, I went with the Hobart Handler 187. Hobart is owned by Miller, and some of the parts are the same but at a lower price. The gun even says Miller on it. http://hobartwelders.com/products/wirefeed/handler187/ I got mine at my local Tractor Supply (TSC) for $600. You will still need to buy a tank ($210) and fill with C25 ($20), and a cart. I have yet to get a 50 foot extension cord ($110). You will also need to have your garage wired for the welder. I did mine myself, but you need to know what you're doing. Most people should have it done. I wired two outlets, one in front and one in the back of the garage. From what I learned before buying, there are three good brands to buy. Miller, Hobart, and Lincoln. Hope this helps.
[Re: The Duster]
#769611
08/09/10 03:19 PM
08/09/10 03:19 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
They aren't the same internally.
The handler 187 is a nice machine.
[Re: Welderman]
#769613
08/09/10 03:42 PM
08/09/10 03:42 PM
TMP66
First of all dont believe all the lies about a 110 volt machine. Dont waste your money!!! A 220 volt machine is the ONLY way to go.
Save up and spend the extra coin. Don't use the 'I'm only going to weld thin stuff' excuse. You might regret a small cheap welder, but never a bigger quality machine. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: TMP66]
#769618
08/09/10 05:28 PM
08/09/10 05:28 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
+1 on the 220 v. I have a Lincoln 170 and it really works well for me. I test drove Miller's and ESAB's before I bought and they were all close in $$$ I just liked how the Lincoln worked.........easier to weld with for me. A purely subjective criterion , but how it felt making beads did it. Big tank of 73/30 CO2 and argon and I have been happy with it for 15 years.
[Re: tubtar]
#769619
08/09/10 05:32 PM
08/09/10 05:32 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Miller 180 here, 220 for frame and roll bar only! 110 will not do it.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#769620
08/09/10 06:12 PM
08/09/10 06:12 PM
Posts: 3,054 Bowling Green, KY
cudaboy
Bowling Green, KY
Agreed, but get one with infinite voltage and wire speed control.
Dennis
[Re: justinp61]
#769621
08/09/10 07:40 PM
08/09/10 07:40 PM
TMP66
I have a Miller 210, it is a great machine, if I were to buy another it would be a Miller 252.
Ditto...![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: The Duster]
#769624
08/10/10 12:16 AM
08/10/10 12:16 AM
Posts: 7,506 Az
Crizila
Az
I forgot the most important piece, the helmet. Do not skimp on the helmet at all. I got a Speedglas 9002X online auction, but there are several good ones to choose from. Things to look at are field of view, how fast it auto darkens. You may or may not want the delay option to stay dark after you stop welding because of your work still glowing, I believe this is mostly for TIG, but could be wrong.
Bottom line, protect your eyes well.
Good info on the helmet Good field of view ( especially if you ware glasses ), adjustable auto darkening and adjustable delay are all features you will want. Quality helmets will start at $150 and up. BTW, you don't need a 220 welder to weld 3/8" plate. I bought a used HTP that has adjustable weld and pause times ( great for stitching pannels ) and will easily weld 3/8" plate. Runs on 110. Unless you are welding outside in the breeze, stay away from flux core mig welders. Gas is the way to go.
Fastest 300
