Thank you for the fast responses. I had already orderd the kit and then find out it is not the 904, it kind of had me worried. Sorry not to get back to you on the bolts, but I plan on getting them from Fastenal. I plan on getting something other than the stock type. Not sure yet on what, just something different than stock in a grade 8. May be overkill, but if you knew me, I'm all about overkill.
Do you know what the stall is on the factory high stall convertors, or know where I can look this up?
