Re: K-1 Technologies Conn Rods
[Re: blownzoom440]
#767290
08/07/10 12:20 PM
08/07/10 12:20 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Metalstorm,
You may in fact be correct.
After the fact,sometimes its just an educated guess, but this isnt Scotts first dance either. I would be willing to bet he has a very good idea what happened.
Just based on my experience/opinion and knowing his experience as well.
RIP Monte Smith
[Re: blownzoom440]
#767292
08/07/10 12:24 PM
08/07/10 12:24 PM
Quicktree
we will never know so speek as you please.should this be in brail for you?J/K i guess i am done here.
you can believe what you want, we know
[Re: Quicktree]
#767293
08/07/10 01:16 PM
08/07/10 01:16 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I run the same rod/piston combo in my stroker and I have had it to 7000 more times than I would have liked but it's still going strong ![](/ubbthreads/images/graemlins/shruggy.gif) Well I hope I didn't jinx myself ![](/ubbthreads/images/graemlins/no.gif) I think Bill's engine just had too many hands on it ![](/ubbthreads/images/graemlins/Twocents.gif) You should be the only one touching that engine from start to finish IMO. Anyways I love my K1's they were almost perfect out of the box,just a little honing on the pin end for a few of them. Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: CompWedgeEngines]
#767294
08/07/10 08:46 PM
08/07/10 08:46 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I can assure you all of one thing. A H-beam style rod just doesn't break in half. Bills problems were clearly from something else.
Also, a spun rod bearing is not the fault of the rod. A spun bearing is either improper rod bearing clearances, poor lubrication, or an oiling problem or over stretched rod bolts ( which would almost always be an old set that are worn out). Lastly would be if there was an oblonged rod big end etc. IF the rod got hot enough, THEN it possibly break. You are talking about a total catastrophic set of conditions to break any ones ( assuming its a quality brand) H beam rod.I'll try and post some pics later of what some customers have brought me, when done wrong.
All I am saying, is I wouldn't be making this a K1 witch hunt based on what has happened to Bill. Those are other issues.
However, Wild Bill and "witch" anything might not be a good idea right about now !
I have to disagree here. There is nothing clear about any of Bills photos, except broken parts. I don't see heat in the rod, but it is broken. Parts DO fail.. And those were the 2 new rods. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Not a witch hunt here. I have a K1 crank in my 950+ hp B1, and it is running great. But I have GRP aluminum rods. ![](/ubbthreads/images/graemlins/laugh2.gif)
Chris.. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Chris'sBarracuda]
#767296
08/07/10 10:12 PM
08/07/10 10:12 PM
Posts: 2,091 Delray beach, Florida
Performance Only
Chris..
by looking at the pictures, i'd suspect either the wrist pin seized or the rings butted together, pulling the rod in two. once cooled back down the rings might be free again, making it easier to overlook that as the problem. a seized wrist can do almost the same thing, although galling will be very evident upon inspection. in my experience, the connecting rod itself is almost never at fault in that type of failure.
machine shop owner and engine builder
[Re: Performance Only]
#767297
08/08/10 12:25 AM
08/08/10 12:25 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Where is the cap, bolts and whats left of the rod?
Ive seen the bolts fail for one reason or another, rod cap come off, crank cuts the rod in half with the help of the block and then sends whats left of the rod right up into the head while its turning.
BB, TT5,Procharged 3300lb Street Car 4.79/154
#767298
08/08/10 12:29 AM
08/08/10 12:29 AM
bigtimeauto
Trophy Winner
Trophy Winner
I have seen this failure also but the piston usually rips apart before the rod
#767299
08/08/10 11:05 AM
08/08/10 11:05 AM
Posts: 16,932 NC
440Jim
NC
Metalstorm,
I wish that cause was posted. He should have told WildBill, and he makes tons of posts. I suspect oiling... I will have to check a couple hundred of Bill's posts, but I thought he had plenty of ring end gap, 0.021"? As long as it wasn't sprayed with nitrous.
[Re: 440Jim]
#767300
08/08/10 01:59 PM
08/08/10 01:59 PM
Quicktree
Metalstorm,
with Jim, same 2 rods. maybe something in the block was clogged up. be nice to know what Scottt thinks happened. you don't make all these posts then never say.....
[Re: Quicktree]
#767301
08/11/10 03:15 PM
08/11/10 03:15 PM
Posts: 17,918 S.E. Michigan
ZIPPY
S.E. Michigan
Metalstorm,
X2
Some kind of suspected cause of failure would be nice to see, from those who have the parts in hand. Accidents happen but some kind of avoidance plan would be a helpful thing.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#767302
08/11/10 04:39 PM
08/11/10 04:39 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I'm not trying to hide anything.
I was trying to stay out of it as I still don't know what went wrong.
I haven't been out to the shop since my last post about the motor as all of my free time since then has been consumed with my daughters racing.
I need to get back out there but the situation with my job has left me very little free time on my hands and as such my girls and their cars have gotten the priority.
FWIW, I think the K 1 rods are a great product for a good price. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: WILD BILL]
#767303
08/12/10 02:22 AM
08/12/10 02:22 AM
Posts: 2,934 Finalnd, Perkele
jyrki
Finalnd, Perkele
This is our fourth season with K1 crank and rods. Dynoed 1580 hp and 1530 ft-lb. No problems so far.
Plynouth VIP '67 TT IC EFI
#767304
08/12/10 10:11 AM
08/12/10 10:11 AM
Posts: 4,213 New York
polyspheric
New York
You mean, except for big-end eccentricity, bearing crush, cap align and bolt position.....
Boffin Emeritus
[Re: polyspheric]
#767306
08/12/10 10:21 AM
08/12/10 10:21 AM
Posts: 13,407 Marion, South Carolina [><]
an8sec70cuda
That would be the fault of the machinist and/or engine builder for not finding these problems before assembly. Very few rods made nowadays are useable right out of the box and all need to be checked prior to assembly.![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: an8sec70cuda]
#767307
08/12/10 10:39 AM
08/12/10 10:39 AM
CompWedgeEngines
Syracuse,NY
Thanks Chip, exactly. If all those things WERE wrong, then you still cant blame the rod. Its the person doing the measuring and assembly.My point again was, rods just dont fail all on their own. I think most people knew what I meant. Then again, what would I know about that, I've only built one engine in my lifetime..... ![](/ubbthreads/images/graemlins/laugh2.gif)
RIP Monte Smith
