Re: K-1 Technologies Conn Rods
[Re: hemiparts]
#767272
08/06/10 11:17 PM
08/06/10 11:17 PM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
The K1 stuff is a very good piece for the money. Some of the better " offshore" stuff, only second to Compstar in my opinion, but way, way better selection for the Mopar crowd. I was one of the very early users of their parts when they first came out. Dan ( DRAM) got involved shortly after as well. We have had very good luck with their products.
RIP Monte Smith
[Re: Moparnut426]
#767275
08/07/10 12:42 AM
08/07/10 12:42 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Not good, just old.... Old is GOOOOOOOD.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Mopar_Rich]
#767277
08/07/10 03:57 AM
08/07/10 03:57 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I would ask Wild Bill. He has gone through 4 rods now, I believe. Pretty sure they are K-1.. So,,,, He could, and most likely would give you an honest overview of them. I'm sure they have figured out what happened by now, and whether the rods were the culprit. It should be interesting.. Chris..
[Re: Chris'sBarracuda]
#767278
08/07/10 04:07 AM
08/07/10 04:07 AM
Quicktree
Chris..
if the rods were the problem shouldn't that have been caught?
#767279
08/07/10 04:11 AM
08/07/10 04:11 AM
Posts: 2,578 sweden
1Fast340
sweden
Chris..
wild bill doesnt count he seems almost haunted when it comes to bad stuff happening sadly:(
[Re: Quicktree]
#767280
08/07/10 05:02 AM
08/07/10 05:02 AM
Chris'sBarracuda
Arizona
Chris..
The first ones spun a bearing I believe. The second just broke, if I remember the pictures.. I have no inside info here. Just waiting to hear as well. But I'm quite sure you can't predict a rod failure. Unless you have a crystal ball.. If you do can you loan it out?
Chris..
#767281
08/07/10 08:01 AM
08/07/10 08:01 AM
Quicktree
Chris..
Chris..
no crystal ball, just find it hard to believe it was a rod failure twice in the same place. if it was I doubt it was the fault of the rod. something else played a roll either way.
[Re: Quicktree]
#767283
08/07/10 08:25 AM
08/07/10 08:25 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Chris..
Chris..
his combo is a stroker i believe so the condition may be for that rod/stroke ratio.i doubt we will ever know unless someone else brakes some with that combo.if rod brke like that on my i sure would not get the same rod again.
[Re: blownzoom440]
#767284
08/07/10 08:31 AM
08/07/10 08:31 AM
Quicktree
Chris..
Chris..
tell me how it was the fault of the rod with spinning a bearing?
[Re: blownzoom440]
#767286
08/07/10 09:17 AM
08/07/10 09:17 AM
CompWedgeEngines
Syracuse,NY
I can assure you all of one thing. A H-beam style rod just doesnt break in half. Bills problems were clearly from something else.
Also, a spun rod bearing is not the fault of the rod. A spun bearing is either improper rod bearing clearances, poor lubrication, or an oiling problem or overstreched rod bolts ( which would almost always be an old set that are worn out). Lastly would be if there was an oblonged rod big end etc. IF the rod got hot enough, THEN it possibly break. You are talking about a total catastrophic set of conditions to break anyones ( assuming its a quality brand) H beam rod.I'll try and post some pics later of what some customers have brought me, when done wrong.
All I am saying, is I wouldnt be making this a K1 witch hunt based on what has happened to Bill. Those are other issues.
However, Wild Bill and "witch" anything might not be a good idea right about now !
RIP Monte Smith
