Re: My 417" W9 Turbo Motor On Dyno (LONG)
[Re: Dos Snails]
#767227
08/09/10 06:24 PM
08/09/10 06:24 PM
Posts: 452 nc
cold85
nc
[Re: go green]
#767229
08/09/10 08:31 PM
08/09/10 08:31 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Well it was like a shooting star..... it was spectacular while it lasted. ![](/ubbthreads/images/graemlins/laugh2.gif) Set pull for 4200-6500RPM this morning..... It was cold & it always makes more boost when cold... It came on brake @ 4200 @ 15.5 PSI & went right to about 16.4 steady.... I should have shut the run down right there, but I knew it was going to make killer TQ, it was already over 1000 TQ right @ beginning of pull, so I figured I'd let it go, it would drop boost down into 14's @ end of pull & we'd mess with boost if necessary after this pull.... Um no, it stayed @ 16.4 PSI whole pull.... I saw around 1050 FT LBS TQ & about 6100 it started rattling, did'nt want to pull to 6500, I knew it right away & I think as I was saying out loud, "pull out of it" Dyno operator was already reading my mind & was pulling back out of pull & POOF... the breathers looked like Exxon Valdez blowing oil everywhere.... My buddy says, "well, it's hurt now" Next thing I know the drivers header is on fire & I'm putting fire out with extinguisher. Guess we found the detonation limits of this fuel & 24 degree timing. ![](/ubbthreads/images/graemlins/shock.gif) Oh well, good learning experience.... took motor back to shop, pulled it down to bare block, everything looks great, other than the obvious..... Took ring lands out on 3 pistons, 1 wristpin should be replaced, obviously new set of rings & the #5 cyl will need a sleeve. It just melted a little divet in the cyl wall that will not clean up, no big deal. The piston in pic is by far the worst out of #5 cyl. The other 2 were just typical broken off chunk of ring land, all rings still intact etc. I ordered a new set of Diamonds for it & doing 4 day expedite so I'll have them @ beginning of week. These were CP's & were pretty light in @ 436 grams, I always thought they were a bit "skimpy" & felt they did'nt make them nearly as stout as typical Diamond N20/Turbo piston, which is usually a massive chunk of aluminum on the top... so decided on Diamonds this time. Bearings showed no signs of detonation from last weeks thrash fest so, I think it only rattled once this AM & that was all she wrote. I'm actually going to re-use the bearings (& the Cometics).... Mains looked great as well. I was really excited to see what the cap walk would look like after 51 pulls. #1 showed none, #3 none, #5 none. #2 was very very minimal & #4 had some, but not nearly anywhere what I expected or have seen out of similar power N20 Motors before. So caps are really staying quite stable @ this power level. So, I should be putting it back together next week. Everything will get a good cleaning & guess I need to order a drum of 116 & learn how to pull more timing out of it ![](/ubbthreads/images/graemlins/tongue.gif) Fun fun fun..... ![](/ubbthreads/images/graemlins/weld.gif)
[Re: RyanJ]
#767233
08/09/10 10:19 PM
08/09/10 10:19 PM
Posts: 10,049 MN
JERICOGTX
MN
Car is looking good Ryan. Looking forward to seeing the ET results once you get it back together.
Jeff
69 GTX
68 Road Runner
[Re: JERICOGTX]
#767234
08/09/10 10:45 PM
08/09/10 10:45 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Ryan, do you have any way of boost referencing your timing? At 14 PSI you may want to be in the teens on timing. No turbo experience I'm just looking at your piston damage. Sorry this happened but you know one of the weak points now. I have always wanted a turbo but just never had the balls to do it. Watched others either run great or go crazy trying and give up. If you are not seeing cap walk with obvious detonation issues seems turbo engines are not hard on cranks. Is that what you are seeing? I have been tempted to boost my engine but the crank is a crower ultralite. Hmm just don't know. Good luck.
Leon
[Re: Leon441]
#767235
08/09/10 11:11 PM
08/09/10 11:11 PM
RyanJ
moparts member
moparts member
State College, PA
Leon
This thing has no where near kind of cap walk I have seen with the N20 motors... I've actually seen worse walk that this with nodular iron MP caps on NA motors in the 650-750 HP range... Yes the turbo seems to be very gentle on the bottom end, it does'nt "shock" everything like the N20.
My current ignition system has no way to boost reference, I do have a timing controller, but not boost referenced, which I think would be a good idea.
Not really planning on running more than 15 PSI in this thing, should'nt have done it this AM. We made bunch of 14.5 PSI pulls Friday with zero issues... another 2 PSI was enough to melt it, So I must have been on the edge which is good info for future. Sometimes you gotta break [Edited by Moparts - Family Friendly Site - Keep it clean] to learn how to keep it together... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RyanJ]
#767236
08/09/10 11:25 PM
08/09/10 11:25 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
What fuel were you running.....any idea what a/f ratio....if on race gas then I would not think you were anywhere near this kind of carnage unless it was getting real lean.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#767238
08/09/10 11:36 PM
08/09/10 11:36 PM
RyanJ
moparts member
moparts member
State College, PA
112 Sunoco, Last pull Friday was 11.2:1 AF average. Most pulls have been in the 11.0:1 range.
Keep in mind my motor is about 11.3:1 compression, this is not a 9:1 piece... & I'd rather not say what cranking pressure on it was. So we were definitely on edge of fuel detonation limits... Problem with living in middle of no where... difficult to get good fuel like C16 or C25, or VP Import turbo fuel.... Have to go at least hour & half 1 way to get VP stuff around here.
[Re: RyanJ]
#767239
08/10/10 12:15 AM
08/10/10 12:15 AM
instigator
north cakalaky
Spent a few hours drilling and tapping the last couple days..Ryan, you think I'll be able to hold in the turbine backpressure ![](/ubbthreads/images/graemlins/grin.gif) top center hit into water jacket about 3/4" back in...nothing some rtv on the stud won't fix ![](http://i249.photobucket.com/albums/gg215/turbocuda/Indy%20motor/2010-08-09190030.jpg) ![](http://i249.photobucket.com/albums/gg215/turbocuda/Indy%20motor/2010-08-09190042.jpg)
[Re: RyanJ]
#767240
08/10/10 12:29 AM
08/10/10 12:29 AM
Posts: 2,091 Delray beach, Florida
Performance Only
there's a bunch of information learned i'll bet. personally with that much compression and boost, i'd be looking at 17* of timing and minimum of 116 octane @ 15 lbs. i'd really prefer 118 though to be completely safe. 51 dyno pulls is a lot of pulls, but in the dyno room the pulls are relatively short and temperatures, among other things, can be controlled. when its in the car and at the track, you have much less control of certain variables. error on the side of caution with fuel, timing and boost, keep a close eye on A/F ratio and EGT if possible (egt should have been used on the dyno for a boosted motor IMO) and read plugs often. that's the best advice i can give from someone who's been there. glad to see the damage wasn't any worse. ![](/ubbthreads/images/graemlins/thumbs.gif)
machine shop owner and engine builder
[Re: instigator]
#767242
08/10/10 03:07 AM
08/10/10 03:07 AM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
That sure is a quick learning curve. ![](/ubbthreads/images/graemlins/biggrin.gif) Didn't realize you had such a high CR, and with no intercooler I would say that if you try to do even anything close to similar you have done so far, you are going to duplicate your results, no matter what the piston brand is. In my opinion way too much boost for that CR and advance. Were all the broken pistons in the center cylinders? We melted a couple of pistons too in the first year with turbos, 8.6:1, 93 octane pump gas and 34 degrees of timing (a mistake)at 14 psi. We dropped the timing some and turned the water circulation over + water in from between the center exhaust ports, and after that it has worked without a hick up. We have an air/air intercooler though, did you monitor your intake temps?
Plynouth VIP '67 TT IC EFI
[Re: RyanJ]
#767243
08/10/10 11:03 AM
08/10/10 11:03 AM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
First off Ryan, I fully respect you and am not questioning you, just some observations. 11.3:1 is nuts. Especially with no intercooler. Have Diamond whack at least a full point of compression off those pistons before they send them, LOL I may not be an expert, but from playing around with the FWD Turbo Dodges I can tell you, you aren't gonna have a street friendly car like you want. Meth injection is nice, but it goes empty just like the fuel tank, and if you have to go an hour and a half to get high enough octane fuel it doesn't seem worth the hassle. Have you consider E-85? Also, I want to hear more from Go Green on the boost creep and wastegate locations. And one more vote for EFI.
[Re: RyanJ]
#767244
08/10/10 01:29 PM
08/10/10 01:29 PM
Posts: 31 California
440Valiant
California
How does a massive chunk of aluminum on the top keep you from burning down the side of the piston?
440Valiant
[Re: Devilbrad]
#767245
08/10/10 06:02 PM
08/10/10 06:02 PM
RyanJ
moparts member
moparts member
State College, PA
I have deck height (ie. Compression height issues) with being able to put more dish in it.
It will be fine, I will just pull more timing out, run better fuel like VP Import, inject the hell out of it with methanol & keep boost below 15 PSI. This thing would have been fine if I had'nt pushed it over the brink allowing it to run over 16 PSI.
This is'nt a car I'm going to drive 100 miles @ a time. It's more of a Cruise night piece... so a 1-2 gallon meth tank under the hood will be fine. The Meth is on a Hobbs switch, so it's not like it will even be coming on @ 1-2 PSI boost when light driving... only come on over 4 PSI or so, & Anytime I'm pushing it over 4 PSI it's going to be more than "light" driving.......
Thicker pistons would not have prevented this mess, but certainly won't hurt VS having a thinner piston if it does go into light detonation etc for some reason.
[Re: RyanJ]
#767246
08/10/10 06:09 PM
08/10/10 06:09 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Would gas porting the pistons have helped? Seems to me the sides would not get as hot if you had a more positive ring seal as in no blow torch blowing between the piston and wall
