Re: Heater & By-Pass Hose Nipples- Tool for Installing?
[Re: BDW]
#76625
06/28/14 10:47 AM
06/28/14 10:47 AM
Posts: 1,083 SE PA
Yellow Fever
SE PA
[Re: Pynzo]
#76626
06/28/14 10:48 AM
06/28/14 10:48 AM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
They're chrome plated steel. The early morning sunrise is reflecting on them making them appear to be brass. Very useful when pulling out frozen/galled old nipples.
Boy..........the last part of that post could sure take this thread off in the ditch . ![](/ubbthreads/images/graemlins/laugh2.gif)
I always just used a small piece of steel, never thought about a tool.
[Re: Pynzo]
#76628
06/28/14 11:44 AM
06/28/14 11:44 AM
Posts: 1,462 Mrytle Beach SC
johnscudashop
Mrytle Beach SC
The only problem with the internal pipe wrench is it grabs the inside and scratches and gouges the gavanizing off the inside of the nipple which in time will cause it to rust, This is why I several mopar engine builders had me make them.
[Re: johnscudashop]
#76630
06/28/14 11:56 AM
06/28/14 11:56 AM
Posts: 21,532 It's a dry heat
gtx6970
It's a dry heat
Ok, I'll bite. pm sent
[Re: gtx6970]
#76632
06/28/14 01:01 PM
06/28/14 01:01 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Jeez guys. A small piece of sheet metal, of the correct thickness, with vice grips or a crescent wrench and the job is done. No special tool needed, no scratching the nipple. Done, simple. Don't overthink the task at hand. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Pacnorthcuda]
#76634
06/28/14 02:30 PM
06/28/14 02:30 PM
johnscudashop
Mrytle Beach SC
Yes, they will rust even with coolant. Look at a set of original nipples the insides are always corroded and a bear to remove.There is a reason why water pump manufacturers galvanize their pump impellers .. Coolant passages in a block are much thicker than the metal the nipple is made out of ,not including the increased pressure through the small diameter nipple that the water passages dont experience..., A piece of sheet metal to turn the slot? Not too sure if that would work.,Reason why is ,The slot is .125 wide and only .150 deep,Since the steel nipples are pipe thread and tapered its very important to make sure the nipples are tight. A peice of sheet metal closest to that size would be 11 ga (around .119 thick) Since its only going down .150 into the slot ,I wouldn't think that you could get it tight enough before the sheet metal fatigues. This is why the aftermarket ones you buy from the Auto Parts Store have a hex on the end to be tightened .These are milled to fit the slot and are made from 316 Stainless steel.They are $40 plus $5 shipping USA. I only made a short supply of these. You can email me direct at jrivinius@sc.rr.com for a paypal invoice. Thank you Moparts
[Re: johnscudashop]
#76637
07/04/14 12:05 PM
07/04/14 12:05 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
Thanks John for providing tools to help hobbyists like me. I have a whole separate drawer in my tool box for Mopar specific tools, all labeled for identification. A friend of mine who's a professional mechanic really likes the torsion bar tool. ![](/ubbthreads/images/graemlins/thumbs.gif)
Common sense is a flower that does not grow in everybody's garden
