Bruno-LibertyXtreme
#765285
08/04/10 05:22 PM
08/04/10 05:22 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Anybody run one? How do you like it?
I am trying to find a deal. May have found one. Then I want to have a browell bell made for my small block. Should be a lot of fun to drive.
Need to get rid of two powerglides to afford it.
Leon
Re: Bruno-LibertyXtreme
[Re: Leon441]
#765286
08/04/10 05:57 PM
08/04/10 05:57 PM
Posts: 1,019 Finland
mafo
Finland
you are gonna love it... It sounds nice too, 9000 rpm and razor sharp shifts I found a link to that other manufacturer, http://www.patdonovanracing.com/
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: Dragula]
#765288
08/04/10 08:07 PM
08/04/10 08:07 PM
Posts: 10,095 MN
JERICOGTX
MN
Can someone tell me the advantage one of these has over a regular clutch? Why not just run a regular Liberty 5 speed, and a single disc clutch? Jeff
69 GTX
68 Road Runner
[Re: mafo]
#765290
08/04/10 08:21 PM
08/04/10 08:21 PM
Posts: 705 Michigan
Hemiroid
I m just to lazy to maintain a clutch
LOL
[Re: toddd]
#765292
08/05/10 05:20 PM
08/05/10 05:20 PM
Leon441
Lynchburg, VA
I have four turbo spline torque converters. 7" 7,600 stall, 8" 7,100 stall, And two 9.5" nitrous converters. Do not want to give them away. The way I understand it a simple gear change in the Liberty and a converter swap and I can run any engine combo I desire. In other word One transmission will do anything I want. Game over in that dept.
[Re: FastmOp]
#765294
08/05/10 06:14 PM
08/05/10 06:14 PM
mafo
Finland
you just have to keep an eye on that liberty... Its very easy to break sliders when you have the converter rotating all the time... always remember to push brake button before engaging a gear. don t ask
[Re: Scamp451]
#765297
08/06/10 12:58 AM
08/06/10 12:58 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Make sure you are at a full stop before engaging the brake to put it in reverse or that will snap the shaft also. I have a 3 speed lencodrive in my 10.5 car. Since its supercharged i don't need the bruno converter drive.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#765300
08/06/10 12:14 PM
08/06/10 12:14 PM
Leon441
Lynchburg, VA
Donald I don't know if this will ever happen. You seem to do well with the clutch. I just have so many skirts to wear(converters).
I am bored to death running this powerglide. They are the greatest transmission sense sliced bread. Every Mopar needs to run one ask anyone. Try so sell one and you find out what people really think of them. I have over $3,500 in each tranny and would be lucky to get $2,000 freshly rebuilt.
Leon
[Re: bigtimeauto]
#765303
08/08/10 10:52 AM
08/08/10 10:52 AM
Leon441
Lynchburg, VA
A Liberty Extreme is a 4 spd. Some guys running a Bruno run a G-force 3 spd.
We run back to back with less than an hour between. With a clutch behind an engine like mine there is some clutch maintenance I just don't have time for. Despite a $3,500 clutch aint cheap. I already have plenty converters to run in this thing.
Many clutch guys make clutches appear the way to go. The fact is those guys with clutch cars that seem to be majical are. Guys like Billy Glidden make it seem that anything else would be retarded. For him that is the case he knows clutches and can listen to his car and know when he has too much or too little and adjust for those conditions with shift points. I'll be the first to admit I'm not that good and don't have the time to get that good with it.
Guess the Scottish wear skirts so they don't get their hardware caught in the unfamiliar zipper.LOL
[Re: Leon441]
#765304
08/10/10 05:40 PM
08/10/10 05:40 PM
mafo
Finland
What kind of oil pressure do you guys use in the converter? Mine is slipping a bit too much, just wondering if higher pressure would fix it...
