Re: 440 bracket motor [Re: SealockRacing] #763406
08/04/10 06:07 PM
08/04/10 06:07 PM
an8sec70cuda Offline
Use the 850 carb.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 bracket motor [Re: an8sec70cuda] #763407
08/04/10 11:17 PM
08/04/10 11:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
get some 4:30's and go racing. should run high 11's with what you got
Coming soon!!!!
Re: 440 bracket motor [Re: an8sec70cuda] #763408
08/04/10 11:32 PM
08/04/10 11:32 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Use the 850 carb.
One more thing,I would try to keep the compression at around 9.5to 1 and run pump premium with that cam.No sense in upping the compression ratio and needing expensive race fuel if you are on a budget.
Re: 440 bracket motor [Re: Dunnuck Racing] #763409
08/05/10 01:28 AM
08/05/10 01:28 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Sorry for your loss.
If you decide to use a set of LY rods, let me know. I have a set here you can have. Also have the matching balancer to go with it. Don't under estimate that cam. My brothers Scamp has a 509 in a 446 that goes 11.40's cast pistons and all. traps about 6400-6500.
Re: 440 bracket motor [Re: Bigbeep] #763410
08/05/10 01:52 AM
08/05/10 01:52 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I think you're on the right track. But yes as was said, use the 850. A kit is cheap if it's a leaker and while yes, it a little too much, it's better than not enough.
Also, PLEASE reconsider the main studs. You will need an align hone and the bolts holes on #3 enlarged. I PROMISE you, it's not worth the expense. The motor will be fine on main bolts!
Keep us posted!
Re: 440 bracket motor [Re: cudadoug] #763411
08/05/10 11:27 AM
08/05/10 11:27 AM
Alexandria, VA
SealockRacing Offline OP
Alexandria, VA
yeah, the 850 has been on a shelf for 20 years or so, so its def getting rebuilt before it goes on the car, i was leaning towards using that anyways haha.
i figure the cam will work just fine for what im using it for, nothing too radical.
im gonna try 93, and also cam2, see which it likes better, i dont mind paying to play since ill only be able to play every so often haha, plus cam2 smells way better!
should i pick up a nice set of arp main bolts instead of the studs than? i didnt know that about #3 hole though...? explain that please? haha
thanks guys
John
Re: 440 bracket motor [Re: SealockRacing] #763412
08/05/10 01:53 PM
08/05/10 01:53 PM
Still have to line hone the mains for ARP bolts. Stick with the stock bolts and you'll be fine.
CHIP
