Re: 440 bracket motor
[Re: SealockRacing]
#763406
08/04/10 06:07 PM
08/04/10 06:07 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Use the 850 carb. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: an8sec70cuda]
#763408
08/04/10 11:32 PM
08/04/10 11:32 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Use the 850 carb.
![](/ubbthreads/images/graemlins/iagree.gif) One more thing,I would try to keep the compression at around 9.5to 1 and run pump premium with that cam.No sense in upping the compression ratio and needing expensive race fuel if you are on a budget.
[Re: cudadoug]
#763411
08/05/10 11:27 AM
08/05/10 11:27 AM
Posts: 602 Alexandria, VA
SealockRacing
Alexandria, VA
yeah, the 850 has been on a shelf for 20 years or so, so its def getting rebuilt before it goes on the car, i was leaning towards using that anyways haha.
i figure the cam will work just fine for what im using it for, nothing too radical.
im gonna try 93, and also cam2, see which it likes better, i dont mind paying to play since ill only be able to play every so often haha, plus cam2 smells way better!
should i pick up a nice set of arp main bolts instead of the studs than? i didnt know that about #3 hole though...? explain that please? haha
thanks guys
John
[Re: SealockRacing]
#763412
08/05/10 01:53 PM
08/05/10 01:53 PM
an8sec70cuda
Still have to line hone the mains for ARP bolts. Stick with the stock bolts and you'll be fine. ![](/ubbthreads/images/graemlins/thumbs.gif)
