Re: who's got the best 440 dampner?
[Re: RobR]
#762689
08/02/10 02:39 PM
08/02/10 02:39 PM
Don't leave out the part about ATI having several BB Mopar units--duh..which one? Different hub lengths --some will clear timing cover, some won't clear certain ones etc big PIA and the big deal with ATI is that they send them out from the factory too small on the ID--with all the different brands of cranks and the small side on the ID you usually have to have a shop HONE the indside for decent fit--yea they need to be tight but not THAT tight--measure before you go to install--if someone says they fit easy they had a China crank with the snout on the small side of spec..also ATI's run with no pulleys NEED BOLTS in the pulley holes per ATI instructions or they can come apart---READ the instructions and CALL them as they have enough choices to get you in the weeds with a quickie order.
[Re: 70blackfish]
#762691
08/02/10 03:25 PM
08/02/10 03:25 PM
BradH
There's part of my confusion w/ ATI...
ATI makes a 2 ring and 3 ring the 2 ring fits on without a spacer...
... and there's the other part, especially after I heard that the 2-ring doesn't work as well and the only reason for the 2-ring was to make an ATI that fit w/ any other modifications.
[Re: dOrk !]
#762693
08/02/10 06:08 PM
08/02/10 06:08 PM
DragtimeDodge
I just published a piece about this topic entitled "Crankshaft Vibration Dampers 101" at The Dragtime News, along with other newly added items. Hope you like it. Bob Beucler DRAGTIME 1964 Dodge Polara www.DragtimeNews.com
[Re: DragtimeDodge]
#762695
08/02/10 06:17 PM
08/02/10 06:17 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i have fluid dampners in all of my motors.never any problems.i was told the engine sees the fluid dampner weight as alot lighter than it's static weight.
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
