5.9 cam in 5.2 - simple but worth it?
#759934
07/28/10 08:46 AM
07/28/10 08:46 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
I found these OEM Magnum cam specs in a book: 5.2 5.9intake duration 251 249 exhaust duration 264 269 overlap 31 41 intake lift .432" .410" exhaust lift .432" .417" cam centerline 113 109 installed c-line(intake) 115 117 intake opens BTC 10 7 intake closes ABC 61 62 exhaust opens BBC 63 56 exhaust closes ATC 21 33 How do you think a 5.9 cam would work in a near-stock 5.2? The valve events appear wider on the 5.9 but lift is less. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Yes, a regrind from Bullet is a reasonable investment but I have easy (free) access to both 5.2 and 5.9 cams.
Re: 5.9 cam in 5.2 - simple but worth it?
[Re: Fury Fan]
#759938
07/28/10 10:24 AM
07/28/10 10:24 AM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
I would say go for it if you have the 5.9 cam it sitting right there - and free. I don't know what the difference would be with the Magnums, but HRM did a base test on a LA 318 and then added a 360 cam and electronic ignition. The combo gave a nice boost to the 318 on the dyno. 318 Street RecipesInspect the 5.9 cam as mentioned, but I think it will be in pretty good shape. I pulled a roller cam out of a well used 5.9 and it looked like new.
[Re: mopowergtx]
#759941
07/28/10 01:28 PM
07/28/10 01:28 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
if you have a degree wheel and dial indicator, map out some of the durations at .050, .1, .2, etc lobe lift. that'll tell you which cam has more area under the curve. the 318 cam might end up with more area under the curve if it has a more aggressive lobe profile and more lift... for example, my bullet regrind is 259 degrees adv, 208@.050 and 127@.2, .316" lobe lift (.506 calculated at the valve) they have another lobe that is 268 adv, but only 204@.050, and only 112@.2 with .290 lobe lift. (.464 calculated at the valve)....I guarantee the "smaller" 259 degree lobe will make more power than the bigger 268 degree lobe...
[Re: patrick]
#759942
07/28/10 01:30 PM
07/28/10 01:30 PM
Posts: 3,075 Eastern Ohio
mopowergtx
Eastern Ohio
for example, my bullet regrind is 259 degrees adv, [Email]208@.050[/Email] and [Email]127@.2[/Email], .316" lobe lift (.506 calculated at the valve)
they have another lobe that is 268 adv, but only [Email]204@.050[/Email], and only [Email]112@.2[/Email] with .290 lobe lift. (.464 calculated at the valve)....I guarantee the "smaller" 259 degree lobe will make more power than the bigger 268 degree lobe...
Definately.
[Re: mopowergtx]
#759943
07/28/10 09:18 PM
07/28/10 09:18 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have a bunch of parts from both motors sitting around and I always swap them the other way around, I prefer the 318 cam. The shorter duration will give more cylinder preassure and the extra lift will work together for more TQ, even if it has a hair less total area under the curve witch I doubt it would if you only count the area when the intake is open and the piston is goin down and the ex. when the pistons going up. Over lap may give you a little scavenge effect at a narrow RPM window but not much.
[Re: ahy]
#759945
07/28/10 09:47 PM
07/28/10 09:47 PM
Posts: 15,487 Florida
scratchnfotraction
I have done that on a couple pre mag 318s use a stock 4-v 360 cam in a 2-v 318seat of the pants dyno..it ran better and had more top end but I run junk,so any help is a gain ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: scratchnfotraction]
#759946
07/29/10 07:39 AM
07/29/10 07:39 AM
patrick
Grand Haven, MI
look at it this way, too....IIRC, the original mag 318 ('92) was rated at 230HP. the following year it was dropped to 220, and the 360 was 235. there was no change to the 318 other than slightly smaller exits to the exhaust manifolds. in '98, when they upped the power ratings (mainly due to exhaust changes after the cat), the 318 went to 235, and the 360 to 245-250.....
I guess if the 360 cam were a better cam, I'd expect the 360 to have more than a 15hp advantage. I'd expect ~20-30hp advantage from the increased displacement alone...
