Re: Comp Lifter Noise/Clacking at 2k RPM Symptoms/Questions
[Re: kz5rt2]
#759438
08/03/10 01:30 PM
08/03/10 01:30 PM
Posts: 2,826 NY usa
540challenger
NY usa
-UPDATE-
I took the valve covers off over the weekend to replace the gaskets as they weren't sealing as well as trying to check out the lobes on the cam. I zeroed the pushrods and applied another 1/2 turn on the rocker adjustments as a friend was rotating the engine. After all that was done, I put on the new rubber/cork gaskets and started it up. The noise was worse than ever! The valve cover gasket walked in when I tightened down the bolts as well. So I tore them back off and I noticed the adjustments on the rockers were hitting the baffles. This must have been my noise I was hearing around 2k rpm and during transitions, not sure why this rpm range and not idle. I also took out the distributor to look at the front two lobes on the cam which appeared to be okay.
I beat the baffles down a bit, put the covers back on and it's quiet. I'll be monitoring it for now.
hope thats sloves your problems. Heck, at least it beats having a wiped out cam lobe.
[Re: eightlitermopar]
#759441
08/04/10 09:33 AM
08/04/10 09:33 AM
Posts: 121 Detroit, MI
kz5rt2
Detroit, MI
Which valve covers are you running?
I currently have the XE cam in my 383 and I do have the "dull sewing machine" noise while driving as well.... I've just accepted it although it annoys me at times
I am running chrome 426 street wedge valve covers.
[Re: Banzaiii67]
#759444
08/04/10 01:03 PM
08/04/10 01:03 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Which lifters did you run? You may want to make sure you don't have too much preload on them now. The 822-16 (stock type) lifters should want the normal .030-.050" preload. The 867-16s (anti pump-up) only want .010".
