Re: What should I expect?
[Re: 602heavy]
#758788
07/28/10 04:43 PM
07/28/10 04:43 PM
Posts: 8,166 Left Coast
BobR
Left Coast
My 4300lb 440 combo went from 12.5 to 10.9 on a 250 hit........had my fair share of mishaps along the way..... balloned convertor which took out main bearings/crank , lifted ring lands on pretty much all pistons , blistered molly off the rings on most cylinders , snapped a couple of half shafts , tore the ring & pinion up , blew throttle plates off , set light to wiring along bulkhead , sheared front planetary gears , blew a core plug out..........seem to have a better handle on things these days.
Not unusual.
