small hammer and light taps to work the thin metal back into shape
i use a thin coat of the copper rtv,rub it on with finger and make a nice thin coat
install on engine and snug it down with a 1/4" drive ratchet or nut driver by hand
let cure over night,resnug it to check
should seal right up
2 foot 2x4 is good stand on the edge and lay vc on it top side down,then tap around all the holes and work the vc around the 2x4 for the coners
extra set of hands to hold 2x4 while you hold the vc and work the hammer helps
studs are ok,
clean every thing down with brake clean...heads and vc then air dry
