Re: Procharged Duster (video) & breakage
[Re: 1Fast340]
#758000
07/29/10 01:58 PM
07/29/10 01:58 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
That Procharger set-up makes good power but everyone I know that has one, has had horrible valvetrain trouble with the gear drives. And the gears themselves in the gear drive your deff not the only one. Steve always breaks the valves right above the keeper. I t got so bad he bought an extra complete head so they could just swap heads when one broke.
One day I will have something cool here.
[Re: sdaurity]
#758001
07/29/10 02:48 PM
07/29/10 02:48 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
Why would that be hard on the valvetrain?
[Re: cudarex]
#758002
07/29/10 06:14 PM
07/29/10 06:14 PM
Posts: 778 Sherwood park, Alberta.
go green
Making power will find the weak link every time . You know where the failure happened ,, try to figure out the why ( physical properties , bad geometry ,parts flexing ,ECT ) and move on . Four second cars do not fall from trees , you have to work for it. Fix it and hit it hard.
[Re: cudarex]
#758003
07/29/10 06:37 PM
07/29/10 06:37 PM
Posts: 2,578 sweden
1Fast340
sweden
i would say that the geardrive transmits and creates some cracy harmonics that get all out of hand at this level,not that i have any kind of experience with this just a thought that hit me
[Re: W8n2DustU]
#758004
07/29/10 11:52 PM
07/29/10 11:52 PM
Posts: 415 Peru
cbarracuda
Peru
Nice car sorry to hear that my titaniun is strong in tensible tests,it has good high temperature strength and is lighter than steel but titaniun has certain disadvantage is amongst the worst bering material imaginable it has a propensity to weld at the slightest provocation to anything that rubs against it.A bet you use ceramic titaniun intake valves they can stand enormous temperatures without any degradation aditionally it doest conduct heat well.so it is good for an intake valve.However they are strong in compression and a valves main stresses are in tension an area where they failed abysmaily
[Re: cbarracuda]
#758005
07/30/10 09:53 AM
07/30/10 09:53 AM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
Actually appears to be caused by the intake seat falling out! Looks as though it may have came out and lodged in the exhaust valve. Causing the piston to hit the valve and breaking the head off the valve. Head is being repaired now, piston on order, and everything else is being inspected!
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
