Re: PICS OF SHACKLES WITH SS SPRINGS.
[Re: tubtar]
#753890
07/23/10 04:43 PM
07/23/10 04:43 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
Ok...When doing this I would guess that you would have to bolt the sliders to the leafs then weld it to the frame....My question is...Do you weld it to the frame when the leaf is in the front,middle or back of slider???? When useing sliders,should you use aluminum bushing in the front?? Tubar...did you say it dropped your car down 1"??? My new hangers dropped it down about an 1" so if that will give me another 1",that would be GREAT!!!!
[Re: 68hemiss]
#753894
07/24/10 08:49 AM
07/24/10 08:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I am running into the same issue on a 68 Barracuda S/S clone. I am using the DC offset front hangers and shackles. When I mocked up my Dana, the rear shackles are pointed forward, it seems that the wheel is moved forward slightly in the wheelwell and the car sits WAY too high. I am using 10.5"x29.5" slicks and I realize that I will have to elongate the wheel openings in the front area for the bigger diameter slicks but the shackle position and rear ride height has to change. I am thinking about de-arching the springs about 2" but won't this change the spring rate decreasing the effectiveness of the S/S springs? I would think flattening out the spring some would also correct the shackle angle as well? I really don't want to add blocks to the rear spring hangers. Thoughts?
No it wont change the spring rate if they put it back to what it was after de-arching it... it would only lower the end point of the spring, any good spring shop can do it
[Re: MIKES_DUSTER]
#753895
07/24/10 10:00 AM
07/24/10 10:00 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Do you have a pic of your car so I can see the stance??
Not just yet. The car is still in the air............but the height reduction is based on where I see the rear spring eye compared to where it was with shackles. I also moved the front eye back 3/4 of an inch when I installed the front spring hangars and should have gone for more. The front of the wheel well will be the first place to hit when stuffing big hides in there. I have nearly 14 " of usable width , so the drawback will be tire diameter. I am at 28 " now with an inch to spare.......but with 3.91's , I think this is going to be just fine. Moving the axle C/L back will allow a taller tire and there is a LOT of room behind the tire.
[Re: MR_P_BODY]
#753896
07/24/10 10:04 AM
07/24/10 10:04 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
do the sliders improve the launch and traction? I have my springs moved in to the frame and i just welded a few tubes in the frame and drilled 3 holes in the front mount so I have 3 mounting location for adjustment if i need to move the rear end. The rear end was farther foward in the wheel opening so i centered it for tire clearance
67' charger 499 RB
10.57 at 127
[Re: MIKES_DUSTER]
#753899
07/24/10 11:16 AM
07/24/10 11:16 AM
MR_P_BODY
I took Mr P Body's advice and a friend of mine made up some aluminum plates/spacers to put in front of the hangers. It moved my rear back 1/2" which makes the tires in the wheel well look better and it also gave me more room to run a 29" tire to fill in the wheel well more.
Doing that,it did help with my shackle. The top is now at about 12:30-12:15 and the bottom is around 6:30-6:15. I will try and take a pic today.
Any other suggestions besides sliders or is that the best and easiest fix??
Your still going to have to move the top of the shackle forward in the rail.... you want 30* - 35* leaning forward with the weight on it
[Re: MR_P_BODY]
#753900
07/24/10 11:36 AM
07/24/10 11:36 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
[Re: MR_P_BODY]
#753902
07/25/10 11:14 PM
07/25/10 11:14 PM
MIKES_DUSTER
Any other suggestions??
