Page 5 of 5 1 2 3 4 5
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hemi [Re: 1_WILD_RT] #75161
01/06/09 08:52 PM
01/06/09 08:52 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Mild steel or Stainless? If Stainless you need to use a few extra steps to stop leaks cause leaking brake fluid will eat the pretty paint off your firewall & frame rail...
Other then that..Looking Great!! Pretty tough being forced to keep a 68 HemiCharger..
That is why I use DOT5 fluid. Looks awsome.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hemi [Re: RoadRunner] #75162
01/06/09 08:59 PM
01/06/09 08:59 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
USPS uses DOT 5 fluid, you should see some of the problems they have because of it...That stuff sucks the moisture out of everything & creates a rusty muck, I haven't seen the same problems in normal applications but Postal trucks definately have issues...
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hemi [Re: 1_WILD_RT] #75163
01/06/09 09:44 PM
01/06/09 09:44 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
I got the OEM mild steel.. Didn't wish to deal with potential leaks.....
Troy
Houston Mopar Connection Club
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hemi [Re: hemi68charger] #75164
01/06/09 09:46 PM
01/06/09 09:46 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Wise Choice!!
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hemi [Re: hemi68charger] #75165
01/06/09 09:49 PM
01/06/09 09:49 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Lookin GREAT Troy! Keep up the good work, she's gonna be one fine ride! That's my favorite color combo on the 68 R/T.
71 440-6 4spd & 69 Hemi 4spd
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hemi [Re: hemi_doug] #75166
01/07/09 12:34 PM
01/07/09 12:34 PM
Houston, Tx
Houston, Tx
Guess I'll need to get some feedback now on the straightening of the fuel and brake lines.. I see there's a big bend in it, which I knew about and expected... But, you only do it once and I wanna get it done right the first time.....
Any words of wisdom from experience on these FineLine kits and their straightening?
Troy
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hemi [Re: hemi68charger] #75167
01/07/09 01:15 PM
01/07/09 01:15 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've always just laid it out on the shop floor & carefully worked the bend out, it has a large enough radius that removing it is pretty easy & if you put a little effort into it you came virtually eliminate the bend....
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hemi [Re: 1_WILD_RT] #75168
01/07/09 01:18 PM
01/07/09 01:18 PM
Houston, Tx
Houston, Tx
Cool, I was thinking of getting some 2x4's next to each other to act as guides and a channel and place the bend in it and work it out... I've heard it's easy...
Thanks Randy.......
Troy
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hem [Re: hemi68charger] #75169
01/07/09 01:27 PM
01/07/09 01:27 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I unbent mine by hand. They are gentle bends and seemed to come out pretty easily.
01/12 Update - brake lines - My '68 Hemi [Re: 69Cuda340S] #75170
01/13/09 08:33 AM
01/13/09 08:33 AM
Houston, Tx
Houston, Tx
I went a head and started and it wasn't as hard as I envisioned, much to the opposite of what others have already stated that have "been there, done that"....
Soooo, one more step closer............ next, fuel lines..........
bad angle on the picture.. Sorry gang........
In the front waiting for the valving.
Went a head and cleaned up the original c-clips for the flexible hoses.. If I can save an original piece, it's going back on....... Original on the left.
Same pics in my question on lines, but wanted to updatee this thread...
Troy
Re: 01/13 Update - fuel lines - My '68 Hemi [Re: hemi68charger] #75171
01/13/09 11:21 PM
01/13/09 11:21 PM
Houston, Tx
Houston, Tx
Another step forward... Got the main 3/8 fuel and 1/4 return line in this evening.. Pretty smooth sailing, but did have to tweak things in the engine compartment area on both.. I can see why this is so much easier with nothing in the way and up in the air...
Troy
Re: 01/13 Update - fuel lines - My '68 Hemi [Re: hemi68charger] #75172
01/13/09 11:22 PM
01/13/09 11:22 PM
Houston, Tx
Houston, Tx
Another in the rear.....
Troy
Re: 01/13 Update - fuel lines - My '68 Hemi [Re: hemi68charger] #75173
01/13/09 11:22 PM
01/13/09 11:22 PM
Houston, Tx
Houston, Tx
wrapped around the quarter on its way to the fuel tank..
Troy
Re: 01/06 Update - brake/fuel/tranny lines - My '68 Hemi [Re: RoadRunner] #75174
01/15/09 08:51 PM
01/15/09 08:51 PM
Houston, Tx
Houston, Tx
Tinkered with the '68 some more today... Cleaned up the original valve and hooked up some more lines..... New parts are awesome.
Troy
