Re: Water from the tail pipe?
[Re: roadrunner7853]
#751053
07/18/10 11:59 AM
07/18/10 11:59 AM
Posts: 1,436 Oklahoma City OK
Cudajon
Oklahoma City OK
It is possible that there was some junk in the bottom of a bolt hole that when the header bolt was screwed in punched a hole through to the water jacket. I have seen this happen so many times its disgusting. Takes a minute to clean out bolt holes with a tap or high pressure jet, even poking a pick in there will get it and yet people keep doing it. The give away is that the bolt was tightened to stop the leak. If the bolt had bottomed out the extra torque pushed something somewhere. )added) sorry I went on a rant. ![](/ubbthreads/images/graemlins/rant.gif) Pull the header bolts one at a time if you strike water you've found the problem. I don't think D4 Hemi heads have bolts into the water jackets.
#751060
07/19/10 02:03 PM
07/19/10 02:03 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
How does lack of sealant on a header bolt allow water into the tailpipe? Unless the guy he-man tightened the stud/bolt so far to crack the head between the bolt and the port, but then I think you'd have an external leak also.
[Re: RapidRobert]
#751063
07/19/10 03:23 PM
07/19/10 03:23 PM
Fury Fan
Indiana
part of the bolt thread will grab the threads of the hole but there's still room for ~15psi of coolant to pressure thru. I use the OE shouldered studs w permatex #1 w headers and trim the outer fine threaded section so there's only enough threads left for a thin high grade nut to fit flush as any extra is a waste & contributes to the fitment prob
Yeah, I realize that, but some of the responses are suggesting that a leak around the threads is making its way inside the header tube, which is where I'm befuddled. I'm not trying to be argumentative (not in this case, anyway ), just trying to learn something new?
A water leak around the threads should want to go to atmospheric pressure (an external leak), not to atmospheric +2-3 psi that is in the exhaust (out the tailpipe). I am presuming the headers in question have gasket between the bolt/stud and the port exit, like a typical bigblock. This means that when the guy re-tightened the headers to seal an exhaust leak, he broke the seal on the stud, sealed the header to the outside world, but the stud now passes coolant to the header tube 'inside the perimeter'?
