Re: Is 210-220 too hot for 440 Big Block [Re: stumpy] #749236
07/16/10 06:04 PM
07/16/10 06:04 PM
Mansfield,Ohio
moparrulzzz Offline
moparrulzzz  Offline
Mansfield,Ohio
Is the OP going to give a list of what hes runnin', shroud, clutch..what!!
Re: Is 210-220 too hot for 440 Big Block [Re: stumpy] #749237
07/16/10 08:17 PM
07/16/10 08:17 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Yes 160* is too cold a stat it should be at least 180* to get the engine up to a good efficient operating temp.
Not to start any arguments or anything, but how, or what determines "efficient operating temp."?
I've been using a 160* stat for over 40 years, with no adverse effects on the engine or oil. Why should I change if what I have works for me?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Is 210-220 too hot for 440 Big Block [Re: moparrulzzz] #749238
07/16/10 09:39 PM
07/16/10 09:39 PM
Kenosha, WI wi/il border
BobN Offline OP
BobN  Offline OP
Sorry -worked late
here is info
stock Iron 346 heads. had 3angle valve job
Mild 440,.040 over, RPM intake,Comp XE268 cam,
KB Hyper pistons . Mancini alumin water pump housing, Mopar hemi water pump,stock crank,
71 Mopar 3core 26"radiator, stock shroud,Mopar clutch fan. 180 thermostat,
dynod at just about 400 HP & 500 torque.
aftermarket cheap temp gauge could be off.
that is what I have been thinking.
Since radiator never pukes out.
I dont really want to go with aluminum rad or electric fans if I dont have too.
does drop to 199 -200 when moving but starts creeping when in traffic.
i was thinking of just letting it go and see if it over heats or not\I also take off out of traffic before is gets over 210 or higher.
what do you think?
Re: Is 210-220 too hot for 440 Big Block [Re: BobN] #749239
07/16/10 10:13 PM
07/16/10 10:13 PM
IN
ahy Offline
ahy  Offline
IN
Agree you are running hotter than desired... not immediatly dangerous but not optimal. It sounds like the basic setup is very good and should keep you cool but running at 200 when cruising down the road suggests the radiator is borderline plugged - it should run cooler.
A good radiator shop can inspect and re-core your OE radiator if it needs it. That's where I'd start. There are all sorts of options but a good 3 core 26" should handle your setup fine.
Also, if you are worried about the guage spend $15 on another one and cross check. I never like to blame the guage when its easy to check.
Also it would be worth double checking the timing and distributor advance mechanism. If the initial timing advance is too low or the advance is stuck that could make it run hotter.
Re: Is 210-220 too hot for 440 Big Block [Re: BobN] #749240
07/16/10 10:26 PM
07/16/10 10:26 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
i have a 70 Chrysler Newport with a 383 2bbl. OK it not high HP motor like all the rest of you guys are talking, but when i first got it it would run on the warmer side, 210-220. i went out and bought a new radiator from 1-800-radiators, had it delivered to my house, put it in and now it runs 160-190 depending on the outside temp, 200 deg on 98 deg day with the A/C on.
are you looking for a "numbers" radiator? if not, buy a new replacement and you should have no more problems.
Re: Is 210-220 too hot for 440 Big Block [Re: 68LAR] #749241
07/19/10 04:03 PM
07/19/10 04:03 PM
Sunnyvale, CA
Jeepmon Online content
Jeepmon  Online Content
Sunnyvale, CA
I have to agree with the 160 philosophy... A stat does not regulate operating temperatures.. it only regulates when the water starts to circulate..
I run a 160 stat as I want my engine to run as cool as possible when racing.. but when driving on the street, the temp gauge will always sit at 180-ish..
Re: Is 210-220 too hot for 440 Big Block [Re: Jeepmon] #749242
07/19/10 05:19 PM
07/19/10 05:19 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I'm running a lot too warm on these hot summer days in Georgia myself. Luckily I've got an old school mechanic on speed dial (my dad). I've been throwing parts at my problem with little success. I've tried different t-stats, water pumps, fan clutches, different fans, and external trans cooler, adding a shroud, etc.
My dad pulled a few tricks out of his hat the other night that I need to look at still. I don't have any kind of rubber or metal flap/guard over the top of the front of the radiator. I don't know if this makes a difference at higher speeds but at lower speeds it could be allowing hot air to recirculate from the back side of the radiator to the front (though maybe it could be a problem at speed too). He also didn't make his view of the use of infrared thermometers in automotive cooling systems clear until after I bought one. In his view, unless you have actual probes in the outlet and inlet to the engine you really don't know squat. I think you know a little more than squat but he's a black/white kind of guy.
If a cooling system is working properly, with a 180* t-stat the engine outlet temp should never be above 180*, simple as that. You start going cooler with the t-stats and then you need more heat transfer capabilities.
Re: Is 210-220 too hot for 440 Big Block [Re: Jeepmon] #749243
07/19/10 05:35 PM
07/19/10 05:35 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Sorry but you might want to rethink what you typed there. A thermostat DOES regulate the coolant temp BY letting the water circulate at a set temperature.
I agree with the 160 degree stats aswell. I rather see 160 on the gauge then 190-200. Whenever the tempgauge goes north of 190 on hot days, I'm getting slightly worried if it might go any higher.
Re: Is 210-220 too hot for 440 Big Block [Re: BigBlockMopar] #749244
07/19/10 07:20 PM
07/19/10 07:20 PM
NJ
440challenger Offline
NJ
was the block boiled/cleaned when rebuilt? I would take the rad cap off and look inside your radiator ,then into the cooling slots.make sure these are clear and no rust/sludge is built up inside them. does the car stay cool for a few miles and then keep getting hotter?
Re: Is 210-220 too hot for 440 Big Block [Re: BigBlockMopar] #749245
07/24/10 11:50 AM
07/24/10 11:50 AM
Sunnyvale, CA
Sunnyvale, CA
The key word there is "operating" temperature.. If your normal operating temperature is 185.. 195.. 205.. or whatever.. Once you reach that temperature, the stat will not make the motor cooler.. with the exception of being a flow restricter to help slow down the rate of water passing thru the radiator..
Re: Is 210-220 too hot for 440 Big Block [Re: Jeepmon] #749246
07/24/10 01:21 PM
07/24/10 01:21 PM
Ohio
Todd Offline
Todd  Offline
Ohio
I added a bottle of water wetter and dropped the temp 10*. JMO.
Re: Is 210-220 too hot for 440 Big Block [Re: Todd] #749247
07/24/10 02:59 PM
07/24/10 02:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that stuff works good. IO don't even use anti-freeze anymore.
Re: Is 210-220 too hot for 440 Big Block [Re: Mr.Yuck] #749248
07/24/10 11:48 PM
07/24/10 11:48 PM
Does water wetter have a rust inhibitor in it?
Re: Is 210-220 too hot for 440 Big Block [Re: BigBlockMopar] #749249
07/24/10 11:57 PM
07/24/10 11:57 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I used to think the margin for error was worth it but I now like the 190 stat. If your system is set up correctly, it will not go over 200.
It was 100 here today and very high humidity and my car ever went over 200, at idle, around town low speed, or on the interstate hogging the hammer lane.
i don't even have a shroud of any kind either.
The oil now stays much cleaner, I'm certain that the engine sees less wear.
The cool underhood temps actually caused a lean condition for my carb. It is an AVS so the 3 step rods are hard to come by, 20 bucks a set and it is really just a shot in the dark on getting things right w/o a wide band. So the hotter stat brought things in line.
Re: Is 210-220 too hot for 440 Big Block [Re: Mr.Yuck] #749250
07/25/10 07:56 AM
07/25/10 07:56 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
This is all I'm going to say about Watter Wetter.
http://www.thetruthaboutcars.com/redline-waterwetter%C2%AE-review/
Re: Is 210-220 too hot for 440 Big Block [Re: Commando1] #749251
07/25/10 10:39 AM
07/25/10 10:39 AM
IA
landon1 Offline
landon1  Offline
IA
i'll agree with the article...i put it in and had no measureable difference in temp
'71 Satellite Sebring 440
