Page 2 of 3 1 2 3
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: MR_P_BODY] #745641
07/12/10 12:57 AM
07/12/10 12:57 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: MR_P_BODY] #745642
07/12/10 01:50 AM
07/12/10 01:50 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i sure dont !
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: BobR] #745643
07/12/10 02:43 AM
07/12/10 02:43 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Are they really that cheap that they can't spray another 320ft.... ....I've raced at Norwalk and left my shoes stuck at the traps while walking the track at night. Maybe Bader should make a move on buying NHRA
nhra says that spraying the last 320 feet pass where the fueler shut off chunks the tires on the fuel cars...
And it does. Still no reason to hose the P/S cars.
I disagree. You chunk a tire at 320mph and it can be really bad. The Pro-Stockers can easily fix this issue.....it's called putting some attack in the freaking wing. Bunch of whiners. They run their crap on such an edge of aerodynamics, that the least little bit of slippage makes them ill handling. But they won't dare put any wing in it. That might scrub off a mph. Whiners. I don't see the alky cars having these issues after the 1,000ft mark....why is that...oh yeah, they USE their wings.
Monte
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: Monte_Smith] #745644
07/12/10 04:11 AM
07/12/10 04:11 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
agree Monte ---
DOWNFORCE
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: Monte_Smith] #745645
07/12/10 07:41 AM
07/12/10 07:41 AM
Lehigh Acres, Florida
rickstershemi Offline OP
Monte
and more motor to go with it
Rickster
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: rickstershemi] #745646
07/12/10 11:08 AM
07/12/10 11:08 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
A couple of possibles I see that could happen, 1, and the most likely is that like NASCAR, the NHRA may step in and mandate a certain spoiler or wing angle to get enough downforce to stay stuck, or run the prostockers either before or after the fuel cars are are on the track. Either earlier in the week with the other stockers or after the fuelers have finished. I personally, as a fan, would pay the full price just to see the Prostockers and nothing else. The fuelers are basically just noise and spectackle, seldom is it good, close racing. Just my unsolicited
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: StrokerPost] #745647
07/12/10 01:43 PM
07/12/10 01:43 PM
Camp Point, IL
gofish Offline
gofish  Offline
Camp Point, IL
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: 493_DART] #745648
07/12/10 02:02 PM
07/12/10 02:02 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
WWWAAAAAA !
WJ crying again after a loss.
And he said " it takes NO talent to drive a fuel car . "
what a puke -- RETIRE WJ ! sick of hearing him crying every other race .
Actually you are very WRONG, sir. He clearly stated, "I'm not upset about the loss, he beat me fair and square..." ALL of his comments were directed at the track surface/NHRA. And then he took a shot at the fuel cars/drivers.
He had every right to be hot. Watch the ESPN footage of the first 2 pair...all 4 of those cars were skating around quite a bit on the big end.
Monte, with all due respect...the alky cars make just a "little" more power than a PS car. Hence they can keep applying downforce. Apply the same downforce of a typical alky FC or dragster wing to a PS car...don't think so...
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: cudadoug] #745649
07/12/10 02:23 PM
07/12/10 02:23 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
WWWAAAAAA !
It does not take much wing, to put LOTS of downforce on a door car, especially one running 200 mph. A little wickerbill goes a long way on a car as aerodynamic as a Pro-Stocker. Easy to measure as well. You read it off the RacePak, with the shock sensors. The issue here is, they dont WANT to put wing in, because it scrubs off ET and MPH. They would rather run on the ragged edge, be as fast as they can and complain about the track. I can knock nearly 5 mph out and just crush the tire of the Pro-Mod on an 1/8 mile with a real agressive wing, what do you think that would do on a 1/4 track.
Monte
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: Monte_Smith] #745650
07/12/10 05:38 PM
07/12/10 05:38 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Even the smallest of wings will benifit and help add down pressure at speed.It's been a proven fact for many years.I ran a Hemi B/G Dragster over 30 years ago that liked to ride front tires off the track surface,I was forced to throttle steer it until I added a 24"X12" wing between the front tires and it tracked like a Cadilliac on steriods.
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: B G Racing] #745651
07/12/10 06:16 PM
07/12/10 06:16 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Old WJ would have been fine, if he hadn't brought the driving into it, the last 320 being slick = a logical complaint,,,,,anybody can drive a fuel car = people just saying "what the heck is WJ complaining about now.
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: B G Racing] #745652
07/12/10 06:17 PM
07/12/10 06:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The problem here is all of the teams want to win
so if they add wing they drop a mph or 2 and then
loose... the NHRA has to mandate a angle so all of
the teams have to to the same... JMO but it made
a day and night difference on my car
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: wyoming] #745653
07/12/10 06:20 PM
07/12/10 06:20 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I love P/S as much as anyone, but someday these guys will realize they are just space filler between rounds of fuel cars.
Did the track magically get worse after qualifying? Why didn't they sit out the second round of qualifying if the track was the issue?
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: slantzilla] #745654
07/12/10 06:28 PM
07/12/10 06:28 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I gotta call BS on that one. Some of us like P/S better than any of the Fuel stuff. And the stands don't exactly clear out after the fuel cars are done. NHRA may treat these guys like fill in, but they are the most advanced out there in my book. I don't subscribe, however, to the Warren sniveling session and saying that anyone can drive a fuel car, maybe he meant except him. Even though his message is a good one, he sounds like an idiot sometimes and ruins the whole arguement.
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: camastomcat] #745655
07/12/10 06:40 PM
07/12/10 06:40 PM
Personally, I would much rather watch ProMods over ProStocks any day....although I do believe they are getting the short end of the stick since NHRA went to 1,000' for the top fueler's
Easy fix....make it all 1,000'
Rickster
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: camastomcat] #745656
07/12/10 06:45 PM
07/12/10 06:45 PM
408Dust Offline
408Dust  Offline
Race a class car and see how you get treated scooter....
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: 408Dust] #745657
07/12/10 06:53 PM
07/12/10 06:53 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
What makes you think I don't Spankey?
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: camastomcat] #745658
07/12/10 07:01 PM
07/12/10 07:01 PM
Bottom Feeders....
Rickster
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: Monte_Smith] #745659
07/12/10 07:21 PM
07/12/10 07:21 PM
cudadoug Offline
cudadoug  Offline
WWWAAAAAA !
Monte
Intersting. I THOUGHT they all had the max legal wing on them now to stay stuck in high gear.
Re: {{{ PROSTOCK REFUSES TO RUN @ SEATTLE }}} [Re: camastomcat] #745660
07/12/10 07:44 PM
07/12/10 07:44 PM
408Dust Offline
408Dust  Offline
Well Scooter if you do then anything NHRA does would not come as a surprise to you...
Page 2 of 3 1 2 3
