Re: Need help with wiring please
[Re: beerwolf]
#745438
07/12/10 03:38 PM
07/12/10 03:38 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
I assume you are using a stock style tilt column, something like 70's-80's mopar or GM??? basically here is what most columns have, there is a ING switch set up and then a 7-8 wire plug for the turn/brake lights(horn to) so you will have 3 feeds in to that plug(usually pink,red and white) 1 comes in fron your stop light switch(white wire) 1 comes in from the turn signal flasher 1 comes in from the 4 way flasher then you have 4 coming out 1 right front turn 1 left front turn 1 right rear turn and stop 1 left rear turn and stop you need to hook up the turn indicators on the dash to the RF and LF wires or when you hit the brakes the dash light will come on(been there done that) Oh and the last wire in that plug should be to the horn relay(you also might have a light wire for the key area) depends on what column you have. it sounds like the rear and front wires are hooked up together and are feeding the front turn lights with the feed that should go to the rear only. hope this helps. Ron... let us know how it works out... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: beerwolf]
#745441
07/14/10 09:49 PM
07/14/10 09:49 PM
Mopar Ron
I am still confused, are you saying that the way you operate the turn signals is just with a 3 position toggle switch? power in to the middle and out on the outside posts? if that the case then you must have 2 feeds to the middle post(brake lite feed and turn signal flasher feed) that would be why the front light work like brake lights I would run a 2nd bulb in the tail light for brake lite only, but you would have to run a separate wire for brakes power to the stop light switch and then back to the brake light bulb. and then just run the feed from the turn flasher to the toggle switch and then off to the RR,LR,RF.LF bulbs ![](/ubbthreads/images/graemlins/shruggy.gif) Ron....
[Re: beerwolf]
#745444
07/15/10 07:53 PM
07/15/10 07:53 PM
Mopar Ron
Yes to the switch, only 1 feed to the middle terminal from the flasher, feed for the brake light from the fusepanel to the brake switch to the brake lights. when the turn signal on ok brakes on ok but when both on I have front brake lights on not cool
so in the rear you have 1 bulb for each side, and at some point you have 2 wires hooked together to one of the tail light wires(1 from the stop light switch and 1 from the toggle for turn,yes?)...
I don't know how you could wire it with just 1 bulb and "NOT" get feedback, that is why I suggest having a separate bulb in the tail light for the brake light.
then the 1 bulb will be for running lights and turn and the other bulb is only for brake
do you have room in the tail light to put a second bulb??? thats how I would do it, Ron....
[Re: Mopar Ron]
#745448
07/15/10 08:16 PM
07/15/10 08:16 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
Hey Ron, I would think it would be easier to change the socket to a two filament than add a separate bulb. What kind of vehicle is this? Somewhere in this thread I read he had a GM harness. The schematic would at least tell him what wires are what.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
