Re: Need help with wiring please [Re: beerwolf] #745453
08/15/10 02:40 AM
08/15/10 02:40 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
If your wiring looks like this you need to add diodes where indicated. Forget the colors on my chart, done simply to indicate different circuits.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: Need help with wiring please [Re: Cheeto] #745454
08/15/10 06:53 PM
08/15/10 06:53 PM
Roanoke Va
beerwolf Offline OP
beerwolf  Offline OP
Roanoke Va
I have just finished. You also need diodes at the brake lines so thet will not feed the other bulbs with all on. So materials needed to do this ! off/ on /off or2p2t toggle switch,momentary contact. 2 15 amp 1p2t relays and 4 3 amp diodes ITS ALIVE
