Re: How far back does the fan need to be from the radiator?
[Re: Scojodak]
#744612
07/13/10 04:51 AM
07/13/10 04:51 AM
Posts: 416 Franklin Co. Illinois
runinonmt
I saw a friend at a car show Saturday and he reminded me how i solved his overheating problem. Since he had done about everything I could think of I told him to check the coolant. Sure enough, the coolant was almost pure antifreeze. Cheap and easy to check. Just a thought........ Ron
In sixty-five I was seventeen and running up one-o-one
I don't know where I'm running now, I'm just running on
Jackson Browne-Running On Empty
[Re: Chilort]
#744615
07/13/10 12:22 PM
07/13/10 12:22 PM
Posts: 28,114 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
14* drop across the radiator isn't very good. Under the best conditions you'd get around 40 degrees. If it works, it works. If it's getting hot and you can't see anything better than that, you have a problem with either low air flow or coolant moving too fast.
[Re: Chilort]
#744617
07/13/10 02:21 PM
07/13/10 02:21 PM
feets
Senior Management
Senior Management
Irving, TX
You should get a high temperature drop at idle. The coolant is moving slow enough to spend time in the radiator dropping temperature.
[Re: Chilort]
#744619
07/13/10 03:53 PM
07/13/10 03:53 PM
feets
Senior Management
Senior Management
Irving, TX
If you haven't changed the pulley ratio and the clutch is in good shape, it should be adequate.
[Re: Chilort]
#744623
07/15/10 11:17 AM
07/15/10 11:17 AM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
